Technical > Chassis & Braking
Rear Axle
Weeman:
Is there a way of squaring it up??
I've fitted my Audi wheels and all other wheels but passenger side rear are fine and dont rub... I know that its a common thing for the rear axle to sit slighly off to one side, but can it be squared up??
Any ideas?
G-spot:
Never taken mine off, but is it possible to gain anything by replacing the rubber mounts??
Alternativly you could elongate the holes on three mounting bolts(both sides) and maybe get some shift, but wouldn't want to do to much in case it creates other issues like it moving around by itself!!
PeteG40:
there is some play in the 3 holes which attach the bracket to the car i do believe anyway
giorgio:
[quote pid=1573 author=peteg40 date=1212314573]there is some play in the 3 holes which attach the bracket to the car i do believe anyway[/quote]
this is true, used to align an axel if you get a whack from the rear.
4-wheel alignment is what you need. Also if its off could you measure the length end plate to end plate.
just so we can build a database with all the sizes to check if an axel is straight LOL
Alex:
Could that play be the reason why some Mk3 Polos lean?
Navigation
[0] Message Index
[#] Next page
Go to full version
