Author Topic: Losing the plot - anyone who can suggest a fix for this is my hero  (Read 7522 times)
Offline olethalb
Ok to summarise, g40 in mk1 golf been in the workshop running fine for 2 months in and out, idle perfect never missed a beat
2 days ago ran out of fuel and this is where it all went wrong
Car starts, drives perfectly but will not idle
Parts changed
Blue temp
Co
Ecu
Fpr
Dizzy
Cap and arm
Leads
Plugs
Injectors
3 x idle control valves
Cleaned out fuel rail
Tb
Fitted new fuel filter
Dropped pumps and cleaned out
Dropped some 'petrol magic' in the tank
Checked micro switches on tb with multi meter
Lambda is new bosch and makes no difference if unplugged
All parts removed from mk1 have also been fitted onto running polo g40 and that runs fine with all parts swapped out
Tb gaskets are good
Makes no difference really if blue temp sensor is unplugged
Occasionally runs better with tb unplugged
I'm at the end with this
Any help greatly appreciated
Offline C0UP3
If you lambda isn't making any difference then check the earthing on it plus check the loom for any breaks. Unplugging a lambda should put ecu in safe mode and make the car run a cold start fuel and spark map. Runs richer and will idle higher.
Does it make any difference between hot or cold running?
Offline olethalb
Earthing point is good and new as is loom
98% of the time sputters and cuts out, the 2% it idles at 2000rpm for around a minute then cuts out
Only from stone cold does it idle ok til auto choke comes of
Offline olethalb
Nothing changes if you unplug anything really, only tb sometimes
Offline Etches
  • Still got the G...
Sounds like blue temp wiring has an open circuit, have you checked all the plugs n loom over?
Check alternator and battery as the sensors get the hump without proper voltage
Offline olethalb
Checked idle circuit and blue temp circuit
Battery is new and strong and alternator kicking out decent volts
Surely symptoms of a dying fuel pump would be more apparent at wot?
Offline Alexiskayak_7
What happens at wot conditions. Everything is ok, or you feel a hesitation?
What's ' decent volts' ?
And what's the co pot set to?
How old is the coil?
Offline olethalb
Wot is strong all the way to limiter
Coil was new but tried 2 others
Battery seeing 13.5 when running
Offline olethalb
Re: Losing the plot - anyone who can suggest a fix for this is my hero
« Reply #10 on: July 06, 2014, 07:53:28 am »
Co set to 550 and tried 2 others too
Offline Ben.lopo
  • Cereal
« Reply #11 on: July 06, 2014, 09:42:35 am »
How about the knock sensor?
« Reply #12 on: July 06, 2014, 05:03:25 pm »
1)Have you checked all the vaccum lines and generally all the hoses that are around the inlet manifold
2)Also check the condition o the inlet mani and throttle body gasket by pooring water while it is working.
3)Have you checked the fuel pressure and supply?
Otherwise, check with a multymeter all the terminals of the loom. It is really weird the fact that doesn't change anything while you unplug blue temp sensor and lamda sensor.
Offline olethalb
« Reply #13 on: July 06, 2014, 10:31:46 pm »
Wasn't aware knock sensor would affect idle
I appreciate the suggestions given so far but must say this only happened when it ran out of fuel
There are only 2 vac lines and no servo on this car, all pipes are new and checked
Had the tb off and cleaned it and checked gasket, usually sucking excess air will always cause high idle
Checking fuel pressure tomorrow
Have run continuenvpcy tests on the loom
I'm starting to struggle to belive anything would have failed at the exact moment it ran out of fuel.....
Offline Ben.lopo
  • Cereal
« Reply #14 on: July 06, 2014, 11:01:49 pm »
How old is the tank sometimes with clleaning it out brings up shit in the pipes even tho you've cleaned them out this May have blocked an injector still , but still I'd check knock sensor and lambda
