Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
Oil coming up the dipstick?
« previous
next »
Pages:
1
2
Go Down
Author
Topic: Oil coming up the dipstick? (Read 4418 times)
Dirty Slag
Re: Oil coming up the dipstick?
Reply #15 on:
January 30, 2010, 12:02:12 pm »
Easiest way to work out if your rings are shot is to do a compression test then do it again but this time put a few sperts from an oil can in the cylinder before you screw in the compression tester if the readings are alot higher you can pretty much guarantee its rings or bore wear!
Probably the oldest G driver in the Universe.
Reply #16 on:
January 30, 2010, 01:02:36 pm »
Send that to the as yet un-started top tips corner.
Tommo
Reply #17 on:
January 31, 2010, 10:20:17 pm »
Yeah.
Plus, as someone has alreads stated, if you take off the oil filler cap when the engines running you shouldnt get much blowing out of it. If its breathing like hell then its probably the rings.
lance
Reply #18 on:
January 31, 2010, 10:23:40 pm »
thats not the same on all engines though, most bmw engines wont even run without the oil cap on.
Traders
I know naathing..
Reply #19 on:
February 01, 2010, 07:41:14 pm »
Usually to do with breather systems that rely on a negative crankcase pressure- if managed by the ECU they get the hump quite easily.
Pages:
1
2
Go Up
« previous
next »
Club G40 Forum
Technical
