Author Topic: fitting standalone oil tank  (Read 4154 times)
Offline Jezza-7
Re: fitting standalone oil tank
« Reply #15 on: October 13, 2009, 05:05:02 pm »
Any recomendations on using this oil by redline?
Its the 10WT
http://www.redlineoil-europe.com/motoroil/index.asp?section=Synthetic+Racing+Oils_00009
Offline scotsjohn
« Reply #16 on: October 13, 2009, 07:51:50 pm »
That's what I'm using by the looks of it. All seems OK for me . The short life they're stating's more than likely for stresses in con-rod bearings knocking the shit out of it. Your charger's not got that problem; rollers/tapered rollers? don't have the same lube problems.
Offline Jezza-7
« Reply #17 on: February 03, 2010, 06:30:57 pm »
« Reply #18 on: February 03, 2010, 06:48:35 pm »
well they wont do because they are brake pipe unions so have holes through them.  Although I've used one of them filled with solder by heating it with a blow torch before.
Offline Tommo
« Reply #19 on: February 03, 2010, 06:53:54 pm »
Im guessing you could just use a bolt with the correct thread and a copper washer?
Offline Jezza-7
« Reply #20 on: February 03, 2010, 06:55:00 pm »
Ok i will try find the right threaded bolt or try your idea. I think i might have some at work. Will take my thread gauge tomorrow.
« Reply #21 on: February 03, 2010, 07:13:44 pm »
yeah just any m10x1 bolt with a copper washer will be reet
