Author Topic: Word of warning  (Read 3944 times)
Word of warning
« on: October 17, 2010, 08:57:51 pm »
Evening Gents,
Just a little heads up of a little known problem that can turn into a royal pain in the arse!
Behind the driver's side rear doorcard is a metal pipe- the fuel filler neck breather runs along this and to the lift pump.
Unfortunately when this rusts, it drops onto the inner sill, you can squeeze your hand down and pick up the rusted chunks of pipe.
I'd have a check asap, as mine had made the inner sill start to rust, as such I've now got to cut the whole area out and plate it.
Hopefully you can catch it in time!
Offline DKnight
Re: Word of warning
« Reply #1 on: October 17, 2010, 11:52:35 pm »
seen this happen on 3 cars i have scrapped!
worth checking for the sake of popping the door card off
lets all go and check and post pictures, yes yes.
Offline xrrich
Re: Word of warning
« Reply #2 on: October 18, 2010, 11:27:46 am »
I had to do this a month ago, nasty job
Offline G-fortified
Re: Word of warning
« Reply #3 on: October 18, 2010, 02:59:46 pm »
Yup ! Same on mine ! The metal tube has just about gone. Using one of those telescopic magnet tools can also help getting the little bits out.
Regards Rob  ;)
Offline Petrified
Re: Word of warning
« Reply #4 on: October 18, 2010, 03:53:03 pm »
What is the best action to take if the metal pipe has started to rust but not completely shafted yet?
Re: Word of warning
« Reply #5 on: October 18, 2010, 05:44:48 pm »
James- I'd try to remove any fallen rusty debris, and then use a rust eater on it.
The pipe inside is a plastic vent line, so won't be affected by the rusty outer pipe.
Mine was so crusty I just pulled it out  :o But you'd not be able to cut it out easily...
Offline Raw
Re: Word of warning
« Reply #6 on: October 18, 2010, 06:50:55 pm »
So is it the rust debris that encourages the rust in the inner wing, or is it that it allows water to get caught in there?
Offline kayl0rz
Re: Word of warning
« Reply #7 on: October 18, 2010, 07:12:13 pm »
Offline Turbodaily
Re: Word of warning
« Reply #8 on: October 18, 2010, 07:26:10 pm »
Majority of my metal pipe is awol, lol. had to replace the (bodged) breather pipe not long ago and noticed it wasnt there! someone must have removed it when they lashed it up the last time. Ill have to fish the crusty bits out with a magnet then!
Re: Word of warning
« Reply #9 on: October 18, 2010, 08:29:01 pm »
Encourages it, I don't see the point of the metal pipe- my guess is to pass crash regs...
kayl0rz- Sorry, Gents and kayl0rz  :D
Offline Petrified
Re: Word of warning
« Reply #10 on: October 18, 2010, 09:02:12 pm »
Hope this helps.
A shot with the rear door card removed.
Looving down from above you can specs of rust but luckily nothing major yet.
Offline youngprodigys
  • G 3URO
Re: Word of warning
« Reply #11 on: October 18, 2010, 09:16:42 pm »
strange! i was looking at this not long ago as i was refitting my tank (think what a shit way to route a pipe) and mines mint! but i do remember around my pipe at the top was caked in shit - so it must have kept the bad stuff out
Offline vwmk3jon
Re: Word of warning
« Reply #12 on: October 18, 2010, 09:22:27 pm »
Had a quick look when i whipped the cards off but not really in too much detail.
Offline lance
Re: Word of warning
« Reply #13 on: October 20, 2010, 08:23:16 pm »
looked at mine, was fine but vactan and zinc primer treated it all anyway. cheers for the heads up.
Offline mark_crox
  • www.mk2polo.co.uk
Re: Word of warning
« Reply #14 on: October 21, 2010, 11:34:51 pm »
Yep mine fell apart in my hand
Need to work out how to replace it..  ???
