Author Topic: g40 charger noise need help  (Read 4821 times)
Offline stevie-doh
« on: May 27, 2012, 04:16:22 pm »
how do i go about gettin more noise out of my standard charger
Offline DKnight
Re: g40 charger noise need help
« Reply #1 on: May 27, 2012, 04:26:00 pm »
few pebbles in the inlet will do it
« Reply #2 on: May 28, 2012, 09:20:51 am »
more noise?!?
Offline brownysblower
« Reply #3 on: May 28, 2012, 10:09:31 am »
Turn your hearing aid UP !!!
Offline grayg40
« Reply #4 on: May 28, 2012, 12:25:30 pm »
like to the above comments :)
if its still the v-belts tight ten charger belts to correct tension and use belt grip spray grease stuff of get a set of teethed pullies and belt but this reduces service life
Offline stevie-doh
« Reply #5 on: May 29, 2012, 11:25:31 pm »
dont really want to do much to the engine as its completly standard and sort of want to keep it original thanks for the help buddy
Offline DKnight
« Reply #6 on: May 29, 2012, 11:38:58 pm »
infact losen a few bolts securing it that will cause vibrations and make quite a racket too
Offline stevie-doh
« Reply #7 on: May 29, 2012, 11:41:08 pm »
cheers for that very helpful now
Offline scotsjohn
« Reply #8 on: May 30, 2012, 09:55:35 am »
Most folk want a nice quiet charger mate. Get rid of the standard filter and fit a cone filter. Eventually you'll throw away your pointless sound system which you won't  be able to hear and you and your mates will have to learn sign language, but it will make the noise you want.
You'll probably need to get your charger serviced more often as most cone filters aren't as good at filtering the air as the standard paper filter.
Offline stevie-doh
« Reply #9 on: May 30, 2012, 01:44:25 pm »
thanks for that mate il give it a try see what its like can always go back to the standard version if i wish. thanks again
Offline Justin14100
« Reply #10 on: May 30, 2012, 02:30:22 pm »
the best induction type kit is the jabba sport one as it has a heat shield too
Offline stevie-doh
« Reply #11 on: May 30, 2012, 02:53:45 pm »
were would i be able to get one of those from and how much do they cost
Offline gavin.starr
« Reply #12 on: May 30, 2012, 02:55:47 pm »
Try Jabba Sport maybe
http://www.jabbasport.com/
Offline stevie-doh
« Reply #13 on: May 30, 2012, 05:10:57 pm »
found one of these on jabbasport at £123 which aint bad i thought it would be a good bit more. it says for a jabba r1 would this induction kit fit a standard charger
Offline SuperMario
« Reply #14 on: May 30, 2012, 05:29:25 pm »
Yes
