Author Topic: 1.4 Engine, paddle clutch gbox etc etc  (Read 1344 times)
Offline Tommo
« on: November 19, 2010, 06:32:51 pm »
Right, Best offer (via PM) takes this lot before I take it to the scrappers.
Some of you may remember my car from last year. Got an ABD block with skimmed pistons to reduce the CR to 8.7:1 there is no head on it and the bores have surface rust. The block wants binning anyway as the bores arent the best, the engine came out of a car that had about 120,000 on the clock. The whole rotating assembly (crank, rods, flywheel, pulleys, clutch etc) has been balenced at EDA, so really this all wants to go in a descent 1.3 block with a new set of rings (as the old ones have done starship miles too).
The clutch is a 3 puk solid centre paddle job, and didnt slip at 200 + lbs/ft of torque.
The gearbox is from a polo genesis, its low milage but the last 9000 miles it has done have been very hard ones!
There is a stronger than standard driveshaft included which I bought off hayesey a while ago.
Also still attached are the struts with 60mm lowering springs/shocks.
Also, I will throw in a 4speed box with a welded diff, ideal for drag racing!
All offers welcome! just need this lot gone. Located in huddersfield, w/yorks.
Just a reminder!!!!!....
Offline grungeisdead
Re: 1.4 Engine, paddle clutch gbox etc etc
« Reply #1 on: November 28, 2010, 06:53:21 pm »
sold
