Hey. Been stumped for a while now coz my car doesn't stop. I've replaced most of the set-up, but the brakes feel like they're suffering from brake fade from a hard thrash, but that's from cold without even moving the car. Here's a list of what i've done so someone can see where i'm going wrong:
Brembo 239mm grooved discs- Pagid fast road pads- 22mm master cylinder- Dot 4 mintex fluid- New compensator/ bias valve from GSF- new rear brake cylinders- shoes are ok- fully bled system........same result! No change.
Some people have said change the servo but it's €320 & may not solve the problem.
Others have said adjust the compensator, but there's not even braking power up front,never mind out back.
I'm suspect that it may be something to do with the vacuum lines, because i have a running problem that i think is related.
When the engine has warmed up (after 10mins or so of idling), it's revs drop away slowly until the engine splutters & struggles to stay running & then cuts out. It's not the timing because i've advanced it a titch so she idles about 1100rpm. It also happens when driving, there's just a drop in power & i need to change down or dip the clutch & give a little blip of throttle while the clutch is depressed.
Also, i think i got sold a set of standard rear cylinders, instead of g40 spec. how much would this contribute, if any, to the problem?
Any help would be hugely appreciated because due to the damned recession,i haven't the money to pay an expert to check over it.
Cheers lads.
