Author Topic: Hello to all! A G40 owner from Spain!!  (Read 4095 times)
Offline demoG40
« on: October 07, 2008, 10:19:43 pm »
Hi everyone! G40 alive
I am from Galicia, Spain.
I have a G40 from a few months ago, a real rocket.
although I have a little problem with the car idling.
when i turn on it,  sometimes fails, dances and is quite low rpm, even once it turns off the engine.
does the same when unemployment in a stop.
I've led a workshop officer vw and have looked and adjusted the idling and a few more things but the failure continues.
I am a little tired because of that failure, and here there are no mechanical who want to work in G, because it are unknown here.
I hope some of you can help me!
Another question:
can i  put off a blow to the G40?
Excuse me for my english, i hope you understand me a bit.
Bye!
A huge hug from spain
Offline demoG40
Re: Hello to all! A G40 owner from Spain!!
« Reply #1 on: October 09, 2008, 09:33:29 pm »
nobody?
« Reply #2 on: October 10, 2008, 11:41:15 am »
hi welcome to the forum.
Idle problem sounds like it may be the aux air valve which is underneath the inlet manifold, this is a picture of mine:
the ideal fix is to buy a new one but they are VW-only and not very cheap (I think about £70 in the UK).  You can clean them with petrol or carb cleaner though which should make things better.
Your other question do you mean a dump valve?  This kind of thing:
They aren't suitable for use with a supercharger.  The idea behind things like this is to stop turbo compressors from stalling when lifting off the throttle.  This isn't an issue with a supercharged engine, the boost return valve that VW put on there in the first place is the best method of controlling air flow off-boost.
Offline demoG40
« Reply #3 on: October 12, 2008, 12:58:57 pm »
thanks hayesey!
the dump valve you say me is it i say, i think.
it´s for the sound of the turbos when put off gas (chsssss)
is it?
i don´t understand if you say what it is good or bad for G??
and the other valve for my problem, can you say me if it is accesible easy?
or i have to unmount a lot of parts in the engine??
if is easy i clean it this afternoon.
thanks for all, enjoy the G!
soon i will put some pics of my car
Offline demoG40
« Reply #4 on: October 15, 2008, 01:39:17 pm »
hello.
here you are a pic of my G40, is all original.
i have to paint it new, the old paint is fucking shit.
can anyone say me where is the aux air valve??
« Reply #5 on: October 15, 2008, 01:46:11 pm »
the aux air valve is underneath the inlet manifold.  I believe it is possible to remove it without taking the inlet manifold off.  I've only ever done it by removing the inlet manifold first though.  Here's a pic of it in situ with the inlet manifold removed:
Offline demoG40
« Reply #6 on: October 15, 2008, 02:45:30 pm »
Perfect!
That is on the side of the G?
would only have to remove the "fat" tube of admission and below this there?
a greeting and thank you very much
« Reply #7 on: October 15, 2008, 03:50:17 pm »
it's at the back of the engine, underneath here:
Offline demoG40
« Reply #8 on: October 16, 2008, 11:57:20 am »
thanks man!
this afternoon i will clean it if i can.
thanks!!
Offline demoG40
« Reply #9 on: October 16, 2008, 10:31:56 pm »
Hi!
I clean it 1 hour ago.
the valve is half broken, is slack, i seal it with a product and the idling improved enough, but I have to buy the new valve to change, and change every step sleeves ACCEPTANCE
Thank other time!
Offline vwmk3jon
« Reply #10 on: October 28, 2008, 05:52:43 pm »
its possible to remove without taking the inlet manifold off BUT its bastard fiddly to put back on again (unless you have small hands like me!)
DemoG40 - Hola y recepción al club G40. ¡Su coche es muy agradable, desemejante de mi español que sea realmente pobre!
