Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
eaton spec cam
« previous
next »
Pages: [
1
Go Down
Author
Topic: eaton spec cam (Read 2571 times)
g40chris
eaton spec cam
on:
August 10, 2009, 07:20:52 pm »
does anyone know what lift/duration these PSD eaton spec cams are as i still have mine fitted but im running a g-lader now
and does anyone wanna swap this for a tidy cam for the g-lader
poloeatonm45
Re: eaton spec cam
Reply #1 on:
August 12, 2009, 10:18:14 pm »
i have been trying to find out this for about 2 years now but sitll i dont know what the set up info is lol
g40chris
Re: eaton spec cam
Reply #2 on:
August 16, 2009, 01:44:11 am »
wanna swap it still
poloeatonm45
Re: eaton spec cam
Reply #3 on:
August 16, 2009, 03:27:47 pm »
i would love to have the cam in but everything we have tried dont work the engine just will not run right with the cam in
g40chris
Re: eaton spec cam
Reply #4 on:
August 16, 2009, 04:35:51 pm »
which cam doesnt it work on
poloeatonm45
Re: eaton spec cam
Reply #5 on:
August 16, 2009, 07:31:43 pm »
we think it is holding the exhaust valves open on cylinder 2 and 4 but we have tried everything to get it right but nothing seems to work the car just runs like a bag of crap
Administrators
The CV joint killer
Re: eaton spec cam
Reply #6 on:
August 17, 2009, 09:19:58 am »
that sounds like someone has lapped the valve seats in too far, Andy had a similar problem once too.
Andy
Traders
Re: eaton spec cam
Reply #7 on:
August 17, 2009, 12:43:50 pm »
Yep, I had the same problem with a BV head I've got. It could've been fine with a stock cam if it had a smaller base circle than the aftermarket one I'm using.
Have you tried a static compression test with the Eaton cam installed?
poloeatonm45
Re: eaton spec cam
Reply #8 on:
August 18, 2009, 04:44:51 pm »
my engine will run perfect with the standard g40 cam in but it just wont have this eaton cam at all i had not thought about the valves being lapped in to much could this cause that though ? i mean surely the tiny amount of metal taken off a valve seat would not cause it to be held open?
steve
Andy
Traders
Re: eaton spec cam
Reply #9 on:
August 18, 2009, 05:06:10 pm »
Like I said, I've had that happen to me. Stick the Eaton cam in and then do a compression test.
Pages: [
1
Go Up
« previous
next »
Technical
eaton spec cam
