Author Topic: Brake pads  (Read 6207 times)
Offline grayg40
Brake pads
« on: August 09, 2011, 08:43:24 am »
I just phoned my local VW place and they tell me that the front pads are obsolete now since last march, is this true?
And if so where is the next best place to get pads?
I run std size grooved discs
thanks
Mark
Offline dekerf1996
Re: Brake pads
« Reply #1 on: August 09, 2011, 12:45:43 pm »
I run ferrodo (DS something) pads on my standard replacement brembo discs.
I find this set up better than the drilled and groved discs and radicam pads I had before.
I would recommend them.
Search on line should reveal a good source
Offline G40BLUE
Re: Brake pads
« Reply #2 on: April 23, 2012, 01:48:20 pm »
Could you please give me the link of your replacement Brembo Discs? I thought to change the discs and the pads mas I need to Know if the configuration to have g40 good =)
Re: Brake pads
« Reply #3 on: April 23, 2012, 03:36:42 pm »
Can get the oem brombos from GSF
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Brake pads
« Reply #4 on: April 23, 2012, 03:41:51 pm »
ds2500 pads are highly recommended, i use Ebc Green stuff find them ok for normal driving and light to moderate use. Are very dusty tho ..
grayg40 what power output has your polo got? also what style of driving do you have mainly in this car?
Offline G40BLUE
Re: Brake pads
« Reply #5 on: April 23, 2012, 04:04:05 pm »
I'm sorry but you can explain what is GSF?  ::) http://www.gsfcarparts.com/  right?
« Last Edit: April 23, 2012, 05:05:26 pm by G40BLUE »
Offline G40BLUE
Re: Brake pads
« Reply #6 on: April 24, 2012, 06:40:27 am »
Hi,
so I'm thinking to buy Brembo Max + EBC Green Stuff or Brembo Max + Ferodo DS Performance. Some people informed that the first one is very good, someone told that for best performance I must use Tarox g88 with Ds 2500, but more expensive.What you suggest?
Another thing that I want to put steel Mesh what I shoud do in your oppinion.
thanks very much for you Help
GBlue
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Brake pads
« Reply #7 on: April 24, 2012, 10:33:15 am »
i use brembo max (grooved) discs at the moment and ebc green stuff.
is ok .. but not enough for a high powered g40, on a lightly modded polo this would be fine.
i do not understand "i want to put steel mesh" .. where are you wanting to put the steel mesh ?
Terry
Offline G40BLUE
Re: Brake pads
« Reply #8 on: April 24, 2012, 11:14:56 am »
Terry
I'm Sorry Cables steel mesh. Replace rubber Cables :)
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Brake pads
« Reply #9 on: April 24, 2012, 11:25:53 am »
ah, here we call them "braided hoses"
they are stainless steel braided lines,
you can buy them from Goodrich website. (they are listed as mk1 golf)
Offline G40BLUE
Re: Brake pads
« Reply #10 on: April 24, 2012, 11:38:59 am »
Ah ok Thanks for your Help.
Just one thing, put braided hoses is a good solution or not justified?
« Last Edit: April 24, 2012, 11:51:46 am by G40BLUE »
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
Re: Brake pads
« Reply #11 on: April 24, 2012, 12:09:06 pm »
Good solution as this reduces brake pedal travel.
Rubber slightly expands where steel stas rigid.
Hope this explains
Offline grayg40
Re: Brake pads
« Reply #12 on: April 24, 2012, 12:29:03 pm »
i forgot about this post, i got pads from venom ms, black diamond ones!
they work well with the matching grooved disks
Re: Brake pads
« Reply #13 on: April 24, 2012, 02:39:06 pm »
Yeah.  Didn't realise you weren't in the uk though!
Offline G40BLUE
Re: Brake pads
« Reply #14 on: April 25, 2012, 07:19:25 am »
No problem :)
