Author Topic: Uprated Track rod bushes?  (Read 2799 times)
Offline Etches
  • Still got the G...
« on: June 30, 2010, 07:55:50 pm »
Re: Uprated Track rod bushes?
« Reply #1 on: June 30, 2010, 08:17:56 pm »
yeah used them for years, they are fine
Offline Etches
« Reply #2 on: June 30, 2010, 08:22:43 pm »
Cheers dude
Offline G40BLUE
« Reply #3 on: May 07, 2012, 09:39:09 am »
hayesey I thinking to buying a kit powerflex, whats your oppinion about thist? I use the car in city sometimes but i'm fear that is too hard...
Offline Phil
« Reply #4 on: May 07, 2012, 11:10:39 am »
Avoid the powerflex bushes on the G40.
The inners are ok if you haven't got the rose joint, but the outters tear the ring of the end within a couple thousand miles if driving properly. Doesn't matter how much power you have, record stands at 1k miles on a 55hp coupe s.
I can do bushes that don't break cheaper than that too.
Offline randombadger69
« Reply #5 on: May 07, 2012, 03:26:44 pm »
 ;D
Offline Etches
« Reply #6 on: May 07, 2012, 04:14:15 pm »
tbf i had them powerflex ones on my old G for 20k with a PPS subframe and they were fine. This time I got em from phil J as he does the inner and outer.
« Reply #7 on: May 07, 2012, 06:47:01 pm »
I fucked a few pairs in quick succession and after a massive whinge to Powerflex got another set free. And they've actually lasted, they got fitted just before the prototype subframe several years ago - so maybe loss of ARB made a difference.
They're sat on the shelf now as I've replaced them with our proto adjustable TCAs, so have rosejoint inner and a PPP-supplied outer nylon bush.
