Author Topic: Eaton Mounting ???  (Read 3002 times)
Offline Oily Fingers
Eaton Mounting ???
« on: June 03, 2010, 10:25:38 pm »
Hey, bought this a few weeks ago, but just did a mock up of the mount on the block with the charger on it.
now i got a feeling that this is wrong.
the bit poking up on the right on the bracket is clearly in the way, i try to mount the charger on but the poking out bit, the charger rests right on top!!!
Could get away with cutting that part off and grinding it down???
also i have a feeling this might be a mk2 g40 bracket?????
has anyone got a picture of the mount they use on there Eaton g40's.
Re: Eaton Mounting ???
« Reply #1 on: June 04, 2010, 10:30:28 am »
It's just a standard g40 engine mount.  You didn't buy that as some kind of eaton mount did you?
Offline vwmk3jon
« Reply #2 on: June 04, 2010, 11:53:21 am »
Would they cut that 'sticky up bit' off though Paul as i dont have that although i do have a bolt on my charger which may mate up to it, keeping the charger level instead of how it is now.
Offline vwmk3jon
« Reply #3 on: June 04, 2010, 12:06:22 pm »
Cut it off. Looks as though mine has been in the past........
« Reply #4 on: June 04, 2010, 05:42:43 pm »
nah,  my Easton has the correct bracket bolted to it. Bought it as a normal engine mount.
Think i'll be playing with the angle grinder this weekend!!!!!!
Offline vwmk3jon
« Reply #5 on: June 04, 2010, 07:36:31 pm »
i'm on spacer mode now for my bracket :)
