Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Electrical
gt & g40 sensors
« previous
next »
Pages: [
1
Go Down
Author
Topic: gt & g40 sensors (Read 3413 times)
Gaz_golf_gti
gt & g40 sensors
on:
May 17, 2009, 09:07:35 pm »
hi all im putting a g40 turbo into my mk1 golf i have the loom but i only have the sensors off of the gt all i need to no is which sensors i can used from the gt and which ones i need to buy.
cheers all
gaz
Administrators
The CV joint killer
Re: gt & g40 sensors
Reply #1 on:
May 17, 2009, 09:45:44 pm »
lambda probe
blue temp sensor
dizzy/hall sensor
oil pressure sensors
are all the same, that's all I can think of! Ones that are g40 only:
map sensor (inside the ECU though so I assume you already have that)
co pot/air temp sensor
Alexiskayak_7
Reply #2 on:
May 18, 2009, 12:48:34 am »
+knocking sensor
Administrators
The CV joint killer
Reply #3 on:
May 18, 2009, 09:26:47 am »
yeah I knew I'd forget at least one, that's G40 only too.
Gaz_golf_gti
Reply #4 on:
May 19, 2009, 04:29:21 pm »
thanks for that lads i no where the knock sensor goes
does the co pot/air sensor go on the boost pipe?
and is there only those that are different?
thanks again
gaz
Administrators
The CV joint killer
Reply #5 on:
May 19, 2009, 04:46:36 pm »
yeah co pot/air temp sensor is the one clipped into the solid boost pipe.
Pages: [
1
Go Up
« previous
next »
Technical
Electrical
gt & g40 sensors
