Author Topic: Oil light buzzing  (Read 3731 times)
Offline Gilly
Oil light buzzing
« on: May 30, 2012, 09:32:32 pm »
Hi there, did an oil change and also changed dash loom for a new one but now the oil light is buzzing but only when revving, has anyone has had this problem?
Re: Oil light buzzing
« Reply #1 on: May 31, 2012, 09:54:08 am »
is the dash loom from the same age car as yours?  The wiring changed later on and there's only one oil pressure sensor on later ones.
Offline Gilly
« Reply #2 on: May 31, 2012, 11:07:08 am »
dash loom is from a 1994 polo on a k reg, my polo is a 1991 on a h
« Reply #3 on: May 31, 2012, 11:15:11 am »
yes then the loom will be from one with a single pressure sensor.  You'll need to clocks to match really.  Or run your own wire from the 2nd sensor to the correct pin on the back of the clocks.
Offline Gilly
« Reply #4 on: May 31, 2012, 11:19:05 am »
excellent cheers for your help, ill run a wire from the second sensor to the clocks :)
« Reply #5 on: May 31, 2012, 11:28:25 am »
I think there's a pin-out diagram for the clocks connector in the electronics FAQ section somewhere which will tell you which pin to use.
Offline Gilly
« Reply #6 on: May 31, 2012, 11:33:34 am »
got it, pin 24......cheers for putting that up, a great help
Offline Gilly
« Reply #7 on: May 31, 2012, 03:11:58 pm »
hayesey, which switch do i run the wire from? ones a high pressure and one is low?
« Reply #8 on: May 31, 2012, 04:28:27 pm »
not sure off the top of my head.  Have you got a haynes manual there?  See which sensor goes to which pin on the back of the clocks.  The wires from the sensors go directly into the clocks.
Offline RyanC
« Reply #9 on: July 31, 2012, 07:19:42 pm »
My g40 dose that when u rev it up the light and buzzer gose on and stays on, loom is original :/
Offline ereeiz
« Reply #10 on: August 02, 2012, 06:07:44 pm »
Checked the sensors to see if they're working? From memory one is for <2.5k RPM and the other for >2.5k RPM, although that may be mk2 golf.
Someone had that on here not long ago and turned out to be a dodgy set of clocks. Everything fails sometime!
