Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
Eaton toothed pulleys ?
« previous
next »
Pages: [
1
Go Down
Author
Topic: Eaton toothed pulleys ? (Read 1854 times)
John-125
on:
September 11, 2013, 06:35:04 pm »
Will the bar-tec or the maxrpm kits work on an eaton charger and will sizing be ok ? If anyone could help would be great
Agent47
Re: Eaton toothed pulleys ?
Reply #1 on:
September 11, 2013, 07:53:42 pm »
All i can tell you is that they fit on the shaft, as my 65mm pulley does. But you're probably better off getting Mini ones
http://www.madnessmotorworks.com/madness-mini-cooper-s-lightweight-15-and-19-supercharger-pulley.aspx
z3i
Reply #2 on:
September 11, 2013, 07:58:37 pm »
I can only imagine the tooth profile on the pulleys will be different from the eaton pulley
For example you cant run a toothed supercharger belt on your timing belt because the grooves are different space and profile
davidg40
Reply #3 on:
September 17, 2013, 06:10:06 pm »
G40 toothed pulleys are i bit bigger then the eaton shaft.
I made it fit myself and used the complete toothed pulley kit.
Fitted an opel toothed belt and it is done.
Pages: [
1
Go Up
« previous
next »
Technical
