Author Topic: Is there only 2 earth cables on the engine?  (Read 2925 times)
Offline JimmyG40
« on: August 17, 2009, 09:00:42 pm »
As it says in title, is there 2 earth cables on the engine?
1 from the battery negative to the bodywork.
2 from the supercharger to the chassis leg
there is also one from the coil to the gearbox too, but was wondering if there was another, i couldn't see an obvious one.
Your help would be appreciated
Re: Is there only 2 earth cables on the engine?
« Reply #1 on: August 17, 2009, 09:57:47 pm »
4:
- battery negative terminal to car body
- supercharger bracket to offside chassis leg
- gearbox top mount to nearside chassis leg
- nearside bonnet hinge to terminal in scuttle tray (although this one seems totally pointless)
It's also a good idea to run a wire directly from the lambda earth point to the battery negative terminal to ensure the lambda has as good an earth as it can.
Offline JimmyG40
« Reply #2 on: August 18, 2009, 08:24:00 am »
ok brilliant! thats a big help! thank you very much!
one more thing, lol where is the lambda earth point?
cheers!
« Last Edit: August 18, 2009, 02:13:28 pm by JimmyG40 »
Offline Dan
« Reply #3 on: August 18, 2009, 02:14:37 pm »
lambda earth point is on the inlet manifold.
Offline JimmyG40
« Reply #4 on: August 18, 2009, 02:45:24 pm »
Ok brilliant! thank you very much!
