Author Topic: G40 aint making me smile anymore :-(  (Read 1791 times)
Offline vwgolfR14
« on: May 26, 2011, 09:42:41 pm »
Rite guys more help needed! I have recently serviced the charger and all is running fine and smoothly, but it just doesn't give me the same instant throw back in the seat feeling as before,1st gear is the only gear u can really feel this but before it was felt all the way through the gears! Any ideas? Thanks colin!
Offline xandyx
Re: G40 aint making me smile anymore :-(
« Reply #1 on: May 27, 2011, 01:46:32 am »
maybe your charger is loosing pressure. guess its time for new strips!
Offline dub-disaster
« Reply #2 on: May 27, 2011, 08:22:26 am »
Boost leak maybe?
Offline vwgolfR14
« Reply #3 on: May 27, 2011, 08:45:53 am »
When u say new strips what do u mean? And as far as I can see there are no boost leaks
« Reply #4 on: May 27, 2011, 09:17:11 am »
the ribbed boost hose to the intercooler is often the culprit and can crack and seep air out.
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
« Reply #5 on: May 27, 2011, 10:22:23 am »
if you are running no boost return pipes, try covering the part at throttle and check if you are getting good pressure.
the rubber hose on the boost pipe should inflate pretty quick, only hold for a few seconds though.
alternatively have someone rev your car whilst you listen in the engine bay..
Offline vwgolfR14
« Reply #6 on: May 27, 2011, 12:09:57 pm »
Will double check the ribbed hose after work, can such a small crack ect give so much lack of power tho?
« Reply #7 on: May 27, 2011, 12:57:51 pm »
yeah - my dads g40 didnt actually look like a hole till i poked it - replacing it made a HUGE difference, 3rd gear felt like 2nd!
When you took charger off you remembered the o-ring on the outlet dome didnt you?
Offline vwgolfR14
« Reply #8 on: May 27, 2011, 05:59:41 pm »
Hmmmm oring? Lol any pics of this?
« Reply #9 on: May 27, 2011, 08:04:59 pm »
goes between the outlet dome and the charger
Offline AlexG40
« Reply #10 on: May 27, 2011, 09:12:18 pm »
The other classic place for a major boost leak is the ISV pipe that comes out of the bottom of the long plastic hose. Check it's connected securely both ends.
