Author Topic: Original Capri Green G40  (Read 8247 times)
Offline superchargedpolo
« on: June 15, 2015, 07:47:17 am »
The time has come to sell my 6th and final G40.  I’ve owned them since I was 21 (that was 17 years ago!)  I bought this car off a fellow forum member.  You’ll be able to see the post from November.  I just wanted one last standard G40 before there were none left.  The car has served me well and never missed a beat.
The following work was carried out by the last owner:
Doors off windows out respray around a year ago and the paint looks lovely and clean still.
The front panel has a few rust spots as it wasn't painted when the car was sprayed.
All the glass is genuine vw glass and all original.
The engine was rebuilt around 5000 miles ago, the head was stripped de coked and cleaned, valves lapped in, alloy bead blasted, new stem seals and rebuild.  The block was checked and new main bearings as well as big end bearings were fitted, new metal head gasket and head bolts.
Engine build thread:  http://www.polog40.co.uk/forum/index.php?topic=11423.0
Other items replaced at the sametime:
new exhaust system
new starter motor
new anti roll bar bushes
new track control arm bushes
new twin v belts
engine oil and filter
new air filter
engine breather pod
timing belt
dizzy cap
rotor arm
ht leads
new radiator
rad switch
brake hoses
new brake fluid all round
fresh anti freeze
new top mounts
new front wheel bearings
Work done in the last couple of years:
water pump
clutch
gearbox oil x2
x2 outer cv boots
both temp sensors
coil
distributor
black poly engine mounts
gearstick repair kit
rear drums
rear slave brake cylinders
front discs and pads brembo
The following work has been carried out by me in the last 6 months / 5000 miles:
4 x New Yokohama A539 tyres.  185 60 13
4 x Eiback springs, bump stops and Bilstein dampers all round.
1 x New fuel pump.
Genuine VAG rear shoe kit.
Genuine VAG bee sting ariel.
1 x Set of front bosch aero wipers.
1 x G60 brake master cylinder.
1 x Full service.
As for price, it’s simple, £3,200 if you want to haggle or £3,000 if you want to buy it.  The car has 6 months MOT but I am happy to make that a year for the new owner.
The car is located in Aberdeen, however I will be heading south (to Reading) in a few weeks and can deliver the car there if that helps but you’ll have to have paid in full before I make that journey.
If you are serious just call on my mobile 07407 100792 as I’m not a young lad that can’t be separated from his laptop / email account.
Many thanks
Craig
Offline RyanC
Re: Original Capri Green G40
« Reply #1 on: June 15, 2015, 09:29:01 am »
Taylor's old car! Lovely example this!!
Offline runforrestrun
« Reply #2 on: June 15, 2015, 10:30:52 am »
The paintwork will be second to none - he's done some bodywork for me and he's incredibly skilled. Well worth the money.
Offline Stevejuststeve
« Reply #3 on: June 17, 2015, 12:09:08 am »
that is stunning! i would give anything to have that but lack of money but have 2 cars worth that money sat on my drive :( anyone fancy buying a c2 vts and a modified smart car,lol
« Reply #4 on: June 17, 2015, 08:09:25 pm »
Deposit taken.
If anything changes I will update this post.
Craig
Offline z3i
« Reply #5 on: June 23, 2015, 10:38:17 am »
Ah it's for sale again
Hopefully it's been bought by someone who will keep it stock :P
Haha cheers for the nice words guys. Do miss it... Well until I sit in the Integra anyway
« Reply #6 on: June 29, 2015, 08:07:44 am »
Now Sold.
All the best Tom
