Author Topic: wheel fitment  (Read 1662 times)
Offline paz46
wheel fitment
« on: March 03, 2010, 09:45:29 pm »
ok im after some new wheels for my g40 i know Standard wheels are 13inch 4 x 100mm PCD with an offset of ET 38 with a 57.1m centre bore
iv seen some 14 inch wheels i like that are 7inch wide do i still need a offset of ET 38 or different with them being wider wheels
cheers for any help
paz  ;D
Offline dannyb.G40
Re: wheel fitment
« Reply #1 on: March 05, 2010, 04:07:43 pm »
Not talking from experience but from what i've read, an offset of around ET20 on the front should be ok and still sit in the arch. after that you start getting poke...if thats what your after!
Im not sure if a higher offset will cause bumping on the inside of the arch, but i can't see it with ET38.
The rear can handle a lower offset (i.e stick out further) and still sit in the arch
Offline kompressor1
Re: wheel fitment
« Reply #2 on: April 03, 2010, 09:53:13 pm »
Whit a 7inch wide you need an offset of 28!
