Author Topic: PSD EATON, complete setup!  (Read 8591 times)
Offline youngprodigys
  • G 3URO
« on: July 14, 2011, 06:24:18 pm »
Right guys - in short i cant justify the noise this makes when i go to work at 6am - simple
sounds off its tits but im getting on my neighbours tits
Complete setup really as im going down the turbo route
PSD Eaton bracket - less then 100 miles on kit
PSD toothed pulleys to suit (series 2 black) again 100miles on them
4th generation Eaton M45 - this aint no mini cooper charger - its a brand new aftermarket version with a custom inlet £££££££
Custom Outlet with a 3" bore and il chuck a few samcos in aswell.
K&N filter
PSD Phase 1 stainless steel manifold - no fouling on charger etc etc with a custom heatshield
PSD Eaton camshaft - done about 2k on this as it was on my old eaton setup
Safe map chip - bottom end of map is done by Andy from PPP and runs well.
custom rear bracket
I know i should put up a price but this isnt for sale yet - this kit will be on show at the poloshow so the buyer can see what he's getting and how it runs - it will be circa £900 open to negotiation
parts cost Eaton bracket £295 - toothed pulleys £200sumate Charger £200, 4branch £300, camshaft £180, PPP tinkered map £100+, inlet/outlet £100+
extras including tensioners, gaskets, etc etc
Any questions then please ask
Kieran
Video here
more photos on request
« Last Edit: July 14, 2011, 06:26:44 pm by youngprodigys »
Offline Richg40
Re: PSD EATON, complete setup!
« Reply #1 on: July 14, 2011, 09:03:58 pm »
I'd be interested in the charger, charger bracket and toothies.
Offline matthg40
« Reply #2 on: July 14, 2011, 10:54:11 pm »
Same here
  • G 3URO
« Reply #3 on: July 14, 2011, 10:59:16 pm »
i may split but i dont wana take a massive hit on what this cost me. if i can sell all the bits and make enough i will split. all depends on what price is offered.
And when people see it at the show theyll fall in love with it, i just cant run it because of the noise in my lil cul de sac at 6am
Offline matthg40
« Reply #4 on: July 15, 2011, 12:12:36 am »
Is it that band theny toothed pullies make plenty of noise
  • G 3URO
« Reply #5 on: July 15, 2011, 07:00:49 am »
in englandish? lol
Offline dub-disaster
« Reply #6 on: July 15, 2011, 08:14:07 am »
Just out of intrest, do you know which turbo your going to use and more importantly which manifold as I'm trying to source a decent t25 flanged manifold at the moment and not coming up with much within a sensible price range.
  • G 3URO
« Reply #7 on: July 15, 2011, 09:59:34 am »
not made the decision yet, it will more then likely be custom
Offline matthg40
« Reply #8 on: July 15, 2011, 10:37:12 am »
Sorry mate I meant to say is the charger that loud as my toothed pullies make plenty of noise them selves lol
  • G 3URO
« Reply #9 on: July 15, 2011, 12:09:23 pm »
it has something to do with it because it wasnt as loud when i was running the old mini cooper charger setup on multi V belt
Offline vwmk3jon
« Reply #10 on: July 17, 2011, 02:11:43 pm »
Be good to see how this differs from the piece of sh#t kit I had.....
  • G 3URO
« Reply #11 on: July 17, 2011, 03:59:59 pm »
it differs in many ways from the original PSD. i have a different charger which mkaes the inlet side sooooo much better - the outlet is shaped better to run a larger alternator, the rear hanger is a better fit then some of the others ive seen.
i was planning on running the throttle before the charger to reduce the noise - and the kit ive made will allow the next owner to do this if they wish.
i also found that brackets are not 100% correct and have got a bag of shims to set the mounting position up so you dont eat belts or get stupid wear on the pulleys!
Offline kano
« Reply #12 on: July 18, 2011, 09:27:32 pm »
:D now its my piece of shit hey.......
Id be interested in the cam if you do break
Offline Richg40
« Reply #13 on: July 24, 2011, 07:55:59 pm »
Still going ahead with this?
  • G 3URO
« Reply #14 on: July 25, 2011, 11:05:29 pm »
yes, will be showing it all off at the next few shows but after that it will be sold. reason above still stands.
wurbo will be quieter unless i can get a cheap G60 charger
