Author Topic: Vacuum hose  (Read 2363 times)
Offline M45eatonG40
Vacuum hose
« on: August 15, 2011, 08:02:26 pm »
Can some one please tell me length of the vacuum hose to the ecu please as I cannot find info at all . Regards james
Offline Puncharado
Re: Vacuum hose
« Reply #1 on: August 15, 2011, 10:21:23 pm »
47 cm.
Offline cheys03
Re: Vacuum hose
« Reply #2 on: August 15, 2011, 10:27:34 pm »
ETKA has 460mm for the tube and 40mm for each connector. From memory I went with 50cm total length, from the tip of the ECU connector to the tip of the vacuum take-off on the brake servo hose.
Offline Puncharado
Re: Vacuum hose
« Reply #3 on: August 15, 2011, 10:30:18 pm »
I measured mine at 47cm, hose only, no connectors.
Offline M45eatonG40
Re: Vacuum hose
« Reply #4 on: August 15, 2011, 10:42:20 pm »
Your gentle man thanks for the reply! Regal motorsport told me mine was too short causing flat spots and hesitations fitted one a metre long and said it was better! Broke down on way home and drove worse!! Oh and £133 quid lighter! I found the yellow brown wire too the blue ect sensor snapped! Drives loads better but still down on power slightly and this new hose goes around my dizzy and back up the wiring harness lol it's massive!! Shower of shit wish I ndver bothered now !!
Offline cheys03
Re: Vacuum hose
« Reply #5 on: August 15, 2011, 10:45:51 pm »
1m is approximately the length on the G60, probably where they plucked that number from.
