Author Topic: Power expectations  (Read 4806 times)
Offline Alex
  • Hack
Power expectations
« on: January 31, 2009, 04:30:39 pm »
This is all going to be a bit pie in the sky, but I'm curious.
I had my G40 on the rollers at the 2006 Club Polo rolling road day, and it made 136bhp and 139lbs/ft with the following mods:
Full Blend Supercharger; SNS Stage 5 chip; Bosch 250cc "Green" Injectors; 68mm pulley; GT inlet manifold; De-restricted airbox; Longlife stainless steel exhaust with decat pipe;
I've since fitted toothed belts and had a bespoke PSD remap, bringing it up to similar spec to Robin's when it ran at the same RR day. So an estimated 145-150 - does sound like a big gain from the toothed belts but hey.
In the next few months I'm having a polished and ported head, fast road cam and probably a vernier pulley, plus a rolling road setup and remap on Regal Autosport's rollers.
What do you reckon it'll be making afterwards?
The engine and charger have done just under 100k and do feel very strong.
Re: Power expectations
« Reply #1 on: January 31, 2009, 07:40:35 pm »
so now you've got toothed belts you'll have a 65mm pulley of course.
My guess is going to be 160bhp.  You are still 1272cc right?
Offline Robin
  • 194bhp - 1341 Turbo
« Reply #2 on: January 31, 2009, 11:20:10 pm »
I'd go with 160ish if you are going to map it on a rolling road as you can tweak alot of things if you get a proper custom map.
I am running 166bhp with the following spec
1341cc
Full Blend
Toothies
Front Mount Intercooler
250cc injectors
PPP custom'ish map
1341 high lift cam
GT Inlet
4 Branch
PPP 63mm Exhaust
Metal Headgasket
Should be able to get 180bhp with the mist and a proper PPP custom map to suit.
Offline Alex
  • Hack
« Reply #3 on: February 01, 2009, 12:52:29 pm »
Yeah I was reckoning about 160, I'm still 1272 and at the moment I reckon it'll stay that way, but if I get a rebuild it'd be rude not to add more cubes. :)
While the head's off, is it worth getting a metal head gasket?
Offline djtez
  • aaAAHH CHOOO!
    • its ma bebo site
« Reply #4 on: February 01, 2009, 02:07:25 pm »
i was wondering roughly the sam actually
im still standard cc
i have piper fast road cam
ported and polished head,
gt inlet p/p
g60 green inj
4 branch - decat
63mm exhaust
toothies (65mm)
not sure on charger it looks ported slightly but cant guarantee the stage
decent 57i induction kit with direct cold air feed.
sns stage 5 chip (custom to mods)
i was wondering how much power in mine over 150 i was hopin but if not then ill keep moddin until it is lol
Offline Robin
« Reply #5 on: February 01, 2009, 03:27:25 pm »
I am still running a standard derestricted airbox with a standard paper air filter on mine.
A metal headgasket will obviously increase the CR so i think it is worth it but you may see more pinking like i have.
Offline G40 AD
« Reply #6 on: February 16, 2009, 01:42:34 pm »
hummm... sorry to hi jack but its on topic...
i've just ordered a standard head gasket from vw... would there be any benefit from getting my hands on a metal headgasket...?!?!? i'm going to have the slightest skim i can on the head whilst its off to be ported n pol'd...
Offline Dan
« Reply #7 on: February 18, 2009, 08:47:04 pm »
Stick with the standard one if you have bought it. If you go metal it increases the CR slightly (which you may or may not wan't). If the deck of the block isn't skimmed or really straight it might mot seal too well.
Offline Robin
« Reply #8 on: February 18, 2009, 10:22:20 pm »
if i had the choice i would go for the standard one, the metal one i got is giving me too much pinking.
« Reply #9 on: February 19, 2009, 08:11:35 am »
but robin - don't you have accralite pistons with an increase CR anyway?
Offline polo classic
« Reply #10 on: February 19, 2009, 11:53:45 am »
What chip do you have?
« Reply #11 on: February 19, 2009, 01:27:56 pm »
At the moment a map I put together in the Aldon Automotive car park, so it's miles from being perfect - but it's better than what was in there.
The previous owner had a PSD chip in the car, but as Robin had a stock cam and cylinder head (but 1341cc 9:1 CR pistons) the car pinked its arse off when the base timing was set correctly.
My own car was one of the first few (9:1 CR) 1341cc motors, and I had the same trouble 'til PSD developed their '1341cc' cam which they fitted and Liam retarded the base ignition timing a touch. I then fitted a BV head which allowed me to set the base timing back to stock with the 1341cc base map and not get pinking. Need to get those hot gases out quickly running the higher CR.
« Last Edit: February 19, 2009, 01:32:52 pm by Andy »
