Well this old question rises again
ive just spent the day having a play with my car, to round things up.
My car is sluggish, not as fast as it should be with the mods it has
On start up it sounds rough, as put in another post, but then after a minute or so it picks up and its fine
It has a strong smell of fuel from the exhaust, and it is visual (as anyone at rolling road will have seen)
My fuel consumption is not bad at all, id say it was good even, so rules out any sensor issue, had it vagcom checked and they are all fine
So i checked the timing, and this picture shows what i have found and done today
Now the first pic is what everyone is telling me, and haynes, but i manually checked and when the piston is at its peak, the 2nd of the marks on the crank pulley is the TDC mark, i checked this with placing something in the spark plug hole, and at its peak the 2nd mark is that.
So that confused me to start.
So i moved the timing to the 3rd picture, and it ran much nicer, and pulled strong, and no signs of smelly fuel from the zorst, and it just sounded to run nicer...
I did reset the timing aswell after moving the belt.
The only down side from the 3rd picture, is the obvious fact that it is telling me its not timed correctly, and it did seem to get warm quite quickly...
But that may be down to the actual ignition timing not being right...
Im confused and wondered if anyone has any ideas?
