Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
undoing camshaft pulley bolt
« previous
next »
Pages: [
1
Go Down
Author
Topic: undoing camshaft pulley bolt (Read 1377 times)
vwmk3jon
on:
June 16, 2011, 05:16:24 pm »
Trying to put the 268/268 on but having no luck (as per usual!)
Got the camshaft loose from the head, belt removed (all marked up for timing purposes) but getting the bolt undone to take the pulley off is causing me a headache. Looked in haynes but it never gives you a proper description imo. Anyone know a quick way as its holding things up
youngprodigys
G 3URO
Re: undoing camshaft pulley bolt
Reply #1 on:
June 16, 2011, 05:56:42 pm »
you need to make a "Y" looking tool- and put 2 bolts on each end. you put it in the slots on the pulley and use it as a lever to stop rotation, then use a rachet to undo the nut
vwmk3jon
Reply #2 on:
June 16, 2011, 06:18:11 pm »
ah ha, i see. Hmmmm, i'll go out to the garage to see what pikeytool i can create.
Administrators
The CV joint killer
Reply #3 on:
June 17, 2011, 09:40:23 am »
I either put a 10m socket and extension bar through one of the spoke holes and hold it that way or get a big spanner against one of the spokes and the other end against the engine mount
vwmk3jon
Reply #4 on:
June 18, 2011, 04:43:28 am »
I'll have a go at that cheers Paul. I did try locking the pulley with a bar against the bulkhead but all that seemed to do was rock the engine!!!
vwmk3jon
Reply #5 on:
June 18, 2011, 02:12:52 pm »
Hallelujah, its off
Bit of bar wedged on pulley and against bulkhead AND a spanner wedged in the pulley and against the engine mount and a looooong lever bar and hey presto. Just gotta hope i havent fudged the timing up too much now!!!??
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
