Author Topic: subframe issue  (Read 8080 times)
Offline G4O LP
subframe issue
« on: August 17, 2009, 04:34:04 pm »
I have just fitted a subframe and its catching when on full lock anyone had the same issues?
Re: subframe issue
« Reply #1 on: August 17, 2009, 04:44:57 pm »
what subframe and what is catching on what on full lock?  ???
Re: subframe issue
« Reply #2 on: August 17, 2009, 04:45:26 pm »
have you had the wheel alignment set since fitting it?
Re: subframe issue
« Reply #3 on: August 17, 2009, 05:16:55 pm »
Also what size and offset wheels are you using?
Offline scotsjohn
Re: subframe issue
« Reply #4 on: August 17, 2009, 09:45:20 pm »
I'm running 6.5x14 with a 30 ET and a PPS subframe. I'm getting rubbing when almost on full lock with tracking spot on, but I can live with it. It's the rim itself thats rubbing which sounds really bad but it's not doing any serious damage.
Re: subframe issue
« Reply #5 on: August 17, 2009, 09:55:10 pm »
whats the castor set to?  I assume those PPS subframes allow you to adjust castor in the same way as the PPP ones do?
Offline breadman
Re: subframe issue
« Reply #6 on: August 17, 2009, 10:22:17 pm »
Yeah hayesey, castor adjustment is made in the same way on both frames.
I reckon it's down to the shallow ET30 offset wheels you're running John. This must bring them into contact with the tension struts when on full lock.
Re: subframe issue
« Reply #7 on: August 17, 2009, 10:24:09 pm »
or the fact the wheels are now further forward in the arches than before means the tyre touches the inner wing.
Offline breadman
Re: subframe issue
« Reply #8 on: August 17, 2009, 10:33:31 pm »
Yeah wheels will be further forward, but John said it was the wheel rim rubbing something not the tyre?
Offline G4O LP
Re: subframe issue
« Reply #9 on: August 17, 2009, 10:45:21 pm »
I'm running identical to John is there anyway of putting a stopper on the steering rack?
Re: subframe issue
« Reply #10 on: August 18, 2009, 07:52:54 am »
If it's rubbing on the tension strut that's a design fault.
We've had a few cars rub on full lock- it's usually the brake hose bracket on the passenger side inner wing. Obviously this is only for the PPP ones, I can't comment on the PPS ones.
Re: subframe issue
« Reply #11 on: August 18, 2009, 09:48:43 am »
hmm weird, so is it the compression strut that the wheel is rubbing on?  Still no one has said what is actually rubbing!
Like I mentioned, my tyre will rub the inner wing on full lock but that's because I have 15" wheels with 60mm lowering and increased castor angle.  I live with it, I just remember to not go on full lock, easy enough because it's not my daily driver though.
Re: subframe issue
« Reply #12 on: August 18, 2009, 10:07:06 am »
Salzmann sell a steering rack block to reduce the maximum lock- I guess because like our MOT their TuV test stipulates nothing must foul on full lock.
Offline polo classic
Re: subframe issue
« Reply #13 on: August 18, 2009, 10:29:36 am »
The block is actually included in the Salzman kit
Offline g-subs g40
Re: subframe issue
« Reply #14 on: August 21, 2009, 09:25:35 pm »
hi i'm an old school but been away for about 5 years. still got my g40 but been in storage. bought an s3 since but now it's time to sort out my little girl. i'm 30 now but bought it when i was 19 from holland as a left hand drive and converted it. the body's getting abit tatty all over but my mother happens to have a really nice gt in dark red so it's getting stripped, caged etc. the engines well sorted with various mods up to 170 bhp but i want some form of sub frame for the front, a quick shift if poss or i'll just make one. and advise on getting better fixed top mounts like the golfs. welding not a problem. i've got a set of 280 mm g60 calipers and a set of 278 audi twin pot calipers too if anyone knows where to get the brackets from to fit them??
