Technical => Exterior and Interior => Topic started by: schneil on October 17, 2010, 11:55:11 am
Hi all
This is my first post on here. I've not got a g40, its a std mk3 shell, but I thought I'd ask you guys as its a g40 question.
I want to replace my bee sting aerial. I had one fitted in 2002 and now it's seen better days as the rubber looks perished and the mast is cracked.
From memory its a Hella one. I think I got it from GSF for around 15 quid. Its similar spec to the official VW one as it had a seperate amp feed and aerial connector. It looks like the OEM one in this pic
http://www.polog40.co.uk/forum/index.php/topic,3118.0.html
Anyway two Hella ones are listed on ECP. One at £36 and one at £15 (part numbers 931440010 and 931440100) which is the OEM spec one? There's also one on GSF (part number 892VG0080) for £15 but this doesn't have a brand.
If its £36 is a proper VW one much more?
thanks all
Neil
I've got the £15 on mine and it's OK, but smaller at the base than the OE spec one I had before.
I phoned VW for a Genuine one. they quoted over £120!
£120! Strewth! Oh well, its a no to that one then.
Alex - which one did you get? £15 Hella from ECP?
£15 from GSF - but not Hella
ive got a spare original aerial in a box in my garage - what would you say they were worth? - this is a proper minter as it was taken off a shunted car with low miles on it
