Author Topic: yes G40 not starting! FIXED!  (Read 2408 times)
Offline cheddarcheese
  • i like boobs!
    • supercharged
« on: September 03, 2009, 11:22:10 am »
Just removed the engine to change the gearbox and then popped it back in its hole connected every thing up and it will not start.
engine turns over.
fuel pumps priming.
spark at the leads.
changed ecu,coil,relays.
checked all earths.
fresh charged battery.
any ideas?
andy
« Last Edit: September 04, 2009, 01:45:46 pm by cheddarcheese »
  • i like boobs!
    • supercharged
Re: yes G40 not starting!
« Reply #1 on: September 03, 2009, 02:10:45 pm »
iv changed the fuel line input and output it now fires up but really lumpy and will not hold idle any ideas?
iv checked every thing i just don't no what i am missing it all worked fine before removal.
  • i like boobs!
    • supercharged
« Reply #2 on: September 03, 2009, 02:43:23 pm »
i have to give it gas to get it started then it will rev ok high rpm but low down rpm its extremely lumpy and dies? lots of fuel smelling smoke too?
just checked the spark plugs they are very black? changed them any way for spare one's what could of changed from removing the engine i left every thing connected to the engine when i removed it?
i also noticed that the crank senser lead has a slit in the outer rubber but the internal wires are fine?
« Last Edit: September 03, 2009, 02:50:36 pm by cheddarcheese »
  • i like boobs!
    • supercharged
« Reply #3 on: September 03, 2009, 06:12:55 pm »
the ht leads are setup correctly. knock senser.
  • i like boobs!
    • supercharged
« Reply #4 on: September 04, 2009, 01:45:01 pm »
fixed! it was the big connector on the fuel rail was the wrong way round i new it would be a simple problem but annoying but fixed and now i am going for a drive haha.
cheers rae for the help
Offline Tommo
Re: yes G40 not starting! FIXED!
« Reply #5 on: September 06, 2009, 11:52:45 am »
Haham Rae should have a hotline.
