Author Topic: Distributor  (Read 2412 times)
Offline dub-disaster
Distributor
« on: September 21, 2010, 06:36:05 am »
What are the service parts on a dizzy is it just the cap and rotor and any seals or o-rings ??
Offline SuperMario
Re: Distributor
« Reply #1 on: September 21, 2010, 08:12:50 am »
just cap n arm, only change any seals ect if they knackerd, shouldnt need too to often tho!
Re: Distributor
« Reply #2 on: September 21, 2010, 09:31:22 am »
Dizzys been revived due to rebuild of motor so I'll do seals rotor arm and cap thanks mate
Re: Distributor
« Reply #3 on: September 23, 2010, 11:06:28 am »
you can replace the seals, there is a bigger one round the dizzy body and a tiny one around the shaft that goes into the head.  You can also replace the hall sender but they aren't cheap, worth it if it is physically damaged as they often are (wire connector snaps off body, just a matter of time before it gets a broken wire then).
Re: Distributor
« Reply #4 on: September 23, 2010, 06:09:36 pm »
I'll have a look at mine n check for hall sender damage thanks hayesey
