Comet Blue Coupe S
A Reg 1984
Has a few shell modifications
Front Crossmember removed and braced
Holes made in front valance for intercooler airflow
Couple of minor alterations to front panel to allow radiator to clear turbo that was fitted
Raintray hole for Mk3 Wiring loom
Battery tray, part of the inner wing and jacking point were all rotten, this has all been cut out and welded up.
Interior is stripped out, bar the original early doorcards with no holes, (no carpet, headlining, rear seats) - Fitted with Grey GT front seats in good nick.
£500
All the following wheels are 4 x 100
Borbet BS Staggered 15x7 & 15x8
Goodyear Eagle F1 tyres, 195/45/15, good tread all round.
Inflated with Nitrogen so wont lose air, and will keep far more stabilised pressure when driving.
Wheels are in near perfect condition, bar one slight buckle on the front drivers wheel, the alloy isnt marked and it should knock out fine.
£350
14 x 8 VW Driver Banded Steels
£300 without tyres
£450 with 195/45/14s 2 falkens 2 contis or yokos all near new
14 x 6 Exips
No tyres
Were brand new but the diamond cut finish has suffered laquer peel
£120
All wheels can be posted for £40 - 35 quid courier 5er for suitable packaging.
RPM Stage 2 Power Kit (Chip + 68mm Twin V-Belt Pulley) £80
Jabbasport Custom Mapped Chip + PSD 65mm Twin V-Belt Pulley) £100
Lucas 54 Calipers stripped for powdercoating + seals + pistons and bolts (no carriers) - £40
63mm iirc oil pressure gauge nos - £15
VW Polo and Lupo OEM watercooled oil coolers. - £20 without or £30 with piping - retrofittable to other VW's
G40 ISV - £30
G40 Throttle Body £50
G40 Alternator - £40
G40 Front Grill Badge £25 (fins broken off back)
G40 Rear badge (Missing Pol so says oG40) - £25
G40 Inlet Manifold x 2 - £30 (each)
G40 Exhaust Manifold - £30
G40 ECU with 250kpa MAP sensor fitted - £140
G40 Driveshafts complete with CV's - £80
Piper 272 Cam - New, fitted but engine has not been run - £150
Rover Intercooler - £25
Mk1 Golf GTI Oil Cooler & Lines/Mounting Bracket and Oil filter housing (the housing is 8v gti specific, you will need a sandwich plate for operation in a polo) - £20
front lower strut brace - new - £25
rear lower strut brace - new - £25
Porsche 944 speedometer - £25
Porsche 944 dash console - £25
VDO oil temp guage - £20
VDO oil pressure guage - £20
VDO volts guage - £20
Cheapo Boost Guage - £10
Mk2-3 Single Wiper Conversion - £50
Brand new mini radiator (top fill) - £20
Cobra Fixed Back Bucket seats - £130 for the pair
Please text 07950 675 910
or email yousafn@gmail.com
Location - Central Manchester
I've got loads more parts, just need to start clearing out my store cupboard as its got stupidly full again.
May be tempted to sell the following -
mk1 golf series 1 with G40 turbo engine - £3,500
mk1 polo, no engine but heavily modified chassis - £500
K03 turbo G40 conversion package - £1500
GT25 turbo G40 conversion package - £1500
NOS 1.4 16v head - rebuilt - £300
Shrick Fast Road cams for 1.4 16v AFH - £400
G40 bottom end - no oil pump but otherwise complete £200
G40 heads - various - enquire
Koenig Fixed back reclining recaro seats - £200
