Author Topic: Locked out of saloon boot  (Read 4323 times)
Offline Raw
« on: March 22, 2012, 11:21:52 pm »
The boot on my Mk3 Saloon is locked shut. The key turns in the lock barrel but it doesn't activate the lock to unlock the boot. Obviously this is a real problem on a Saloon as you can't get in to the boot from the cabin. I need to hear from anybody who has some experiance of fixing this problem. Please don't post here for all the world to see how to break into a polo boot but if you have some use full experiance or info to share please PM me.
Thanks,
Andy.
Offline cheys03
Re: Locked out of saloon boot
« Reply #1 on: March 23, 2012, 09:11:36 am »
All I can say is to wish you the best of luck
Offline cheys03
« Reply #2 on: March 24, 2012, 06:44:27 pm »
Has anyone been able to help you out via PM?
Offline Raw
« Reply #3 on: March 25, 2012, 07:44:01 pm »
No - no PM's so far.
Anybody want to hazard a guess as to best approach?
Drill the lock, try and punch it out, Just cut a hole in the boot lid?
« Reply #4 on: March 25, 2012, 08:27:17 pm »
smash a rear light and get your hand in?
Offline scotsjohn
« Reply #5 on: March 25, 2012, 10:39:32 pm »
Drillings the name of the game; keeps damage done to the lock itself.
Offline grungeisdead
« Reply #6 on: March 25, 2012, 10:43:46 pm »
Pm Dublass on club polo, she locked keys out her mk1 derby n got them out. Tell her Saf sent ya her way
« Reply #7 on: March 28, 2012, 10:16:11 am »
drill the lock barrel out and then replace it.  Or hammer it out with a screwdriver and hammer but you risk putting a dent in the boot lid
« Reply #8 on: March 28, 2012, 01:12:40 pm »
If the key turns, but doesn't release the catch, there's no point in doing anything with the lock.
I had a similar problem when the plastic clip holding the bar connecting the lock/catch broke, being a coupe I dropped the seats and flipped the catch open.
As it's a saloon, I'd source a rear light- smash the current one in there and reach around to flip the catch.
« Reply #9 on: March 28, 2012, 01:49:38 pm »
yoof has a fair point there :D
Offline scotsjohn
« Reply #10 on: March 28, 2012, 06:36:10 pm »
Which one costs more?
Offline genesisGT
« Reply #11 on: March 29, 2012, 03:41:43 pm »
remove the rear back seat squab (pull up sharply) and then there are a few holes and gaps round the panel. reach through or use a long nose pliers or screw driver and flip the pull rod up and it will release. can be done through the parcel shelf as well but it has the seat belt brackets etc through it and the speeker holes are quite high up but they are larger so you can get your arm in.
when you get it open would WD 40 it like a mofo then clean and activte it by hand a few times and copper grease it before you shut it again.
Offline Raw
« Reply #12 on: April 05, 2012, 12:42:28 pm »
Only just seen these replies. I've ordered a new light cluster and was waiting on that to arrive but I'll be removing the rear seat back tonight!
Fingers crossed!
Offline Raw
« Reply #13 on: April 05, 2012, 08:15:38 pm »
Just had a look through the rear seat and can't see how the lock barrel connects to the lock! Or anything to hook onto.
Can somebody please post a pick up of their lock? ideally a saloon but coupé may do as I'd be able to tell if they were the same lock or not.
Cheers.
Offline youngprodigys
  • G 3URO
« Reply #14 on: April 06, 2012, 01:25:21 pm »
there will be a rod mate going from the lock down to the catch - pull it up!
