Author Topic: Pipe missing?  (Read 2016 times)
Offline BrettG40
Pipe missing?
« on: April 25, 2009, 07:59:26 pm »
Hi guys,
just purchased a G40 today, well happy with it. Just a quick question though, the pipe that normally goes from top of charger in through rocker cover, out rocker cover and onto throttle body is non existent, a blanking plate is in place on the charger, and i have a slight oil leak which i presume is from a breather pipe that should be connected to the missing pipe, any ideas?
Thanks.
Brett
Offline BrettG40
Re: Pipe missing?
« Reply #1 on: April 25, 2009, 08:37:54 pm »
Can anybody help me out??
Re: Pipe missing?
« Reply #2 on: April 25, 2009, 09:08:40 pm »
it's quite a common modification to remove the "boost return" pipe.  The oil leak sounds like whoever did it hasn't connected the breather pipe up to a catch tank which you have to do when removing the boost return pipe.
Offline BrettG40
Re: Pipe missing?
« Reply #3 on: April 25, 2009, 09:22:31 pm »
Oh ok, thanks for your reply, so the throttle body and rocker cover stay as they are with no pipe on them at all? Ok ill look into a catch tank, or purchase all the required pipes.
Offline vwmk3jon
Re: Pipe missing?
« Reply #4 on: April 26, 2009, 01:15:16 am »
theres a catch tank on ebay at the moment.
