Technical => Engine and Transmission => Topic started by: supercharged spaniel on November 08, 2008, 03:48:36 pm
I've put together a full table of every part for the block and head for a full rebuild excluding electrical/sensors (ill do a seperate one for those) it would be good however if i could get the torque settings too and add this to the sheet. Then i'll email it to hayesey who hopefully can put it on here as a downloadable document?
i was thinking torque settings for:
head bolts
crank bolt
fly wheel bolts
main end caps
big end nuts/bolts
sump bolts
rocker cover bolts
and any others that available?
engine only please
Oh... I have Autodata book that writes in there... I'll send you the torque of these bolts in Monday...
The head bolts are bolted with that way:
10 4 2 6 8
7 5 1 3 9
Main bearings: 1st stage 33NM 2nd stage 65NM
Big end bearings 1st 30NM 2nd 90 degrees
Flywheel bolts 25NM
Camshaft pulley 6NM+ 90 degrees
