I never said the endfloat was 2mm...
I understand completely what you're trying to say- but your principle and reasoning is wrong behind conrod movement.
John- if you're talking about elastic deformation causing lateral oscillations in the crank, then I'm well versed, having sat through hours of advanced engine technology lectures... if you want to understand and be able to calculate and appreciate it's impact then Heinz Heislers Advanced Engine Technology is a good place to start, saw me through a HND and most of the final year of my degree.
If you really want to know about crank flex (and it does happen in extreme cases/ poorly designed ones) then research top fuel methanol big blocks, several thousand horsepower, that use deformation of the main bearing (width) to measure det- an obvious case for 'crank flex' and extreme cylinder pressures causing an excessive force to be placed on the bearing shell. Considering most headgaskets would pop at 90bar cylinder pressure you need to got alot further to get an explosion with a large enough force to 'flex' a crank properly. I understand you're taking about harmonics and a movement of microns (it has to be circa <15 microns to retain a decent oil film on the bearing) but to me 'flexing' is big boy top fuel talk.
Robin, it's a gudgeon pin.... retard
