Technical => Engine and Transmission => Topic started by: retrowagen1234 on November 04, 2008, 07:06:51 pm
What are the benifits for fitting an oil cooler? does the g realy need it? im wondering as i fitted one too my bug and it helped but that had no stack cooler in it. also anyone know a good kit to fit? i see them advertised but not sure on the quality
cheers guys, Dan
the cooler on mine is made by Setrab. Mocal are pretty good too. I'd say rather than buying a "kit", just get a suitably sized heat exchanger and make your own brackets to fit it whereever you want or can fit it. Then go to a local hydraulic pipe place (check yellow pages or whatever) and ask them to make up pipes to suit, shouldn't cost much more than £20 really.
It's definitely a worthwhile mod, oil temps can get sky high when ragging and since the charger is lubricated by the engine oil too (from the factory anyway, youi can fit a stand-alone supply) really high oil temps don't do that any good.
