Author Topic: Fuel pressure regulator  (Read 1560 times)
Offline Jezza-7
« on: October 29, 2010, 03:42:31 pm »
Is it worth buying an adjustable fuel pressure regulator?
I see that FSE are ment to be good but is it a waste of money?
Does anyone use them?
Re: Fuel pressure regulator
« Reply #1 on: October 29, 2010, 03:57:44 pm »
don't see the point on a g40, the ECU needs the fuel pressure to be regulated as it expects or it'll not be able to control fuelling properly.  I've seen one used on a dodgy eaton conversion as a method of forcing more fuel in to cope with the extra power.  But it's pikey as hell! a proper remap is required for stuff like that.
You could also use it in conjunction with a remap to get more fuel through smaller injectors without switching to bigger ones.
Offline newt
« Reply #2 on: October 29, 2010, 08:39:46 pm »
not much point, unless you are having mapping wok done
they are adjustable yes but are not smooth/progesive
i used an adjustable and boost sensative fuel pres reg on my 20v rallye but it was on mbe management and i could map it so it was brilliant
i used it on a big power r5 turbo when i used to do dyno/mapping work , to get more fuel accross the whole range
and it worked well,
 i cant really see it being usefull on a g40, only benefit would be if used in conjuction with a specific injector size and mapping session,say for example to use an injector slightly smaller than g60 (to enable fine tuning at idle as g60 injectors are a little hard to map at idle) and run a slightly higher fuel pressure,
people have probably been "recomended" to use one if you had a power run and it was starting to lean off further upthe rev range, where really you need a bigger /new fuel pump to keep up with demand or fuel pump is on the way out, or the car needs mapping
maybe worth trying one, with a guage! and setting it to factory pressure 3bar?????? maybe
also running wide band and then monitoring afr whilst turning it up say0.2 bar increments.....
