Author Topic: Help - Please:-) - WHAT THE FOOK! interesting results inside  (Read 18043 times)
Offline rich4130
Re: Help - Please:-)
« Reply #30 on: March 04, 2010, 10:06:15 pm »
You got the TT dials etc and everything? Very impressive !
Offline youngprodigys
  • G 3URO
« Reply #31 on: March 06, 2010, 04:19:18 pm »
yes mate. got it all. all working aswell.
anyone shed some light on what's going on with my motor, it's ticking over smoothly at 1000rpm and every now and then (1 minute gap, 2 minute gap) it will miss fire. and it's sporadic aswell. hmmmmmm
  • G 3URO
« Reply #32 on: March 07, 2010, 11:52:43 am »
it is set up to spark on the Z mark. the engine is running smoothly and seams ok - just once in a while it will randomly miss.
  • G 3URO
« Reply #33 on: March 21, 2010, 11:21:13 am »
Ready to scrap this now and break it for parts. cant get it running properly and ive lost all heart in it. developed a new fooking problem now - alternator light is on at idle unless you rev it - then it starts charging. brand new alternator later and another £100 out of my bank balance and nothing has changed.
car runs rough and then cuts out. unless someone comes and helps me out now this car will be broken
« Reply #34 on: March 21, 2010, 11:47:47 am »
could be a shit battery? or poor earth
  • G 3URO
« Reply #35 on: March 21, 2010, 11:56:41 am »
battery is brand new. also tried my dads rover battery which is fine and it does the same on that.
ive checked all i can. unless someone comes and sorts it its going. quite a waste really
  • G 3URO
« Reply #36 on: March 21, 2010, 05:18:05 pm »
yer iv replied on the other thread, its not that - its brand new and is making a really good contact
ive been out on it for the last 2hours checking all of the earths and making sure they are all there and all intact.
i have a thick strap running from the charger bracket to the body.
another on the gearbox to the n/s chassis leg
i have also ran an extra strap from the chassis leg to the inlet manifold earths
and an additional earth to the ignition amp to the chassis leg
any more????
« Reply #37 on: March 21, 2010, 05:19:45 pm »
sounds like some sort of loom issue then to me.
  • G 3URO
« Reply #38 on: March 21, 2010, 05:29:57 pm »
just cant see where i would have one.
all the wires check out when i test the ecu connector against the engine, and the wires from the alternator - all 3 of them lol are present and correct. AAAAAARRRRRGGGGHHHHH
« Reply #39 on: March 21, 2010, 05:43:27 pm »
when you say when you check the engine against the ecu - what do you mean?
  • G 3URO
« Reply #40 on: March 21, 2010, 05:59:24 pm »
check the pins go to the correct sensors on the engine and in the correct place. and also with the ignition on i checked the voltages/earths etc against the ecu on "power on"
  • G 3URO
« Reply #41 on: March 21, 2010, 06:28:25 pm »
timing belt isnt a tooth out as it is as Beavis timed it - all i did was changed the belt for a new 1 and when i did it i tipex'd the belt and the pulleys to ensure they went back in the same way.
blue temp senso is genuine brand new vag tested in a pan of hot water as per your diagnostic guide
"if you've toothed pulleys then i've seen a lot of g40's that the alternator light comes on until it is revved up even though it is outputting the right voltages" THATS WHAT IM TALKING ABOUT! anyone have this problem? it could be that its not spinning fast enough at idle.
« Reply #42 on: March 21, 2010, 07:36:32 pm »
still re-check the timing, people can make mistakes no matter how good a mechanic you think they might be.
I sometimes get the alternator light on when first started up at idle and a quick blip of the throttle gets rid of it and it stays off then.
Offline dub-disaster
« Reply #43 on: March 21, 2010, 07:37:56 pm »
I know this isn't of any help but mine used to do this with toothies on light on untill I just bliped the throttle a little then it went out giving out all the right voltages though !
  • G 3URO
« Reply #44 on: March 21, 2010, 07:55:23 pm »
all parts for sale.
had enough of it.
