Author Topic: Turbo timer  (Read 3573 times)
Offline Jezza-7
Turbo timer
« on: November 24, 2012, 06:19:03 pm »
I got one off a mate for free and thought i might put it in.
I got 3 wires
Red    - 12v constant
Green - Ignition
Blue   - Accessories
How would i wire this in as i cant seem to find much info in the haynes. Obviously red is 12v but im stuck on the green and blue.
Been a while since i started up my G40 but iirc when you put the key in you turn to ignition and then one more and it starts?
So the green goes to ignition but what the hell is accessories?
Any help would be good.
This is the only guide i can find that helps:
Given a test light ground the ground wire , optionally take off the shroud on the steering column to get to the ignition wires, with the ignition key off poke the probe into each wire till you get one that lights up thats your 12V constant (RED) , next put the ignition key in accessories and poke wires again find one that lights up but this time turn the key to off again the light goes out thats your Accessories ( BLUE  Wire ) lastly put the key in ignition ( last position before start ) poke wires again till it lights up and confirm its ignition by switching back to Accessories position it should go off thats where you connect the (Green Wire )
Offline Jezza-7
Re: Turbo timer
« Reply #1 on: November 24, 2012, 06:28:35 pm »
Just found a video and apparently you dont need the accessories one, just the live and ignition one.
Offline vwmk3jon
Re: Turbo timer
« Reply #2 on: November 25, 2012, 10:46:12 am »
im getting one shortly so when it turns up i can scan the instructions and post it up
Offline vwmk3jon
Re: Turbo timer
« Reply #3 on: December 03, 2012, 06:49:56 pm »
ive got mine. i can post up a pic of the instruction diagram if you need one?
Offline Jezza-7
Re: Turbo timer
« Reply #4 on: December 03, 2012, 07:25:36 pm »
What is your one for? Like model?
Mine was for a jap car but you buy a different harness for universal fitting. Does your have the blue wire as well?
I got a diagram but could you post your on up as it might be more helpful to me.
Offline vwmk3jon
Re: Turbo timer
« Reply #5 on: December 03, 2012, 11:51:50 pm »
its an apexi universal one. has alot of info for japcrap in the instructions but doesnt look toi hard to install (he says!)
no blue wire but has the following...
grey wire - to handbrake switch
black - ground
white - O2 sensor signal
then theres the 3 wires that go to the wiring harness and has a plug on the end...
red - 12v positive constant
blue - IG2 output (this the blue wire you meant?)
green - IG1 output
ill post the fitting diagram up as soon as photobucket behaves on my phone
Offline vwmk3jon
Re: Turbo timer
« Reply #6 on: March 07, 2013, 04:16:31 pm »
Did you manage to get yours working Jezza?
want to get mine wired in....
Offline Jezza-7
Re: Turbo timer
« Reply #7 on: March 08, 2013, 07:25:59 pm »
never got round to it. Hopefully that will be something to do soon though.
Offline vwmk3jon
Re: Turbo timer
« Reply #8 on: March 09, 2013, 12:29:57 am »
Gonna have a go doing mine tomorrow but im wiring it in slightly different as mine has a 02  sensor function im not using.
