Author Topic: Toothed Pulleys  (Read 5435 times)
Offline xrrich
Toothed Pulleys
« on: July 10, 2011, 01:35:10 pm »
Decided my next purchase has to be toothies,
Been doing some research and wanted a bit of information
What's better aluminium or steel
And  is there anywhere else to get them from other then here,
http://www.bar-tek-tuning.de/nocache/g40+zahnriemantrieb+glader,w22739.htm
http://www.g-laderseite.de/eshop/product_info.php?products_id=42
Any general information would be great, i want to buy the right ones so don't regret it and end up buying better ones later on
Rich
Offline scotsjohn
Re: Toothed Pulleys
« Reply #1 on: July 10, 2011, 06:31:16 pm »
The G-Laderseite one is a ribbed belt set-up thats not much of an improvement on the existing twin-v set-up. The Bartek effort might be OK, but it has a square section tooth belt/pulley that seemingly howls like a Banshee and is much more prone to belt stripping. There's a differance of opinion on the steel v alloy question; each has plus points. Best wait for a PSD to kit to come up here or e-bay. They're pretty reliable and well made.
Offline Richg40
Re: Toothed Pulleys
« Reply #2 on: July 10, 2011, 07:13:29 pm »
Get the bar-tek one, im gonna.
Re: Toothed Pulleys
« Reply #3 on: July 10, 2011, 10:02:43 pm »
the bartek arent square tooth, but they are steel not alu so are heavy!
Offline Alex
  • Hack
Re: Toothed Pulleys
« Reply #4 on: July 10, 2011, 10:04:49 pm »
Toothed belts are a bit of a dilemma for me.
I love the power delivery, but I really miss the noise of the V belts. :(
I know which I want more, but I can't say I'm a huge fan of the whine. I wouldn't want them to be any louder than the PSD ones.
Offline xrrich
Re: Toothed Pulleys
« Reply #5 on: July 10, 2011, 11:47:40 pm »
Yeah might wait for a set of PSD ones come up, how do the Ali ones wear compared to the steel ones,
Re: Toothed Pulleys
« Reply #6 on: July 11, 2011, 09:04:16 am »
depends how tight people have had the belts, whether they've used correct pitch replacement belts, which run of the PSD ones they are and how many miles they are?
I ran some second hand phase one ones - which had been used for about 50k for about 50 k myself and now samg40 has them and tehy are pretty much like new... whereas i've seen some newer ones which are worn out.
Offline scotsjohn
Re: Toothed Pulleys
« Reply #7 on: July 11, 2011, 08:52:09 pm »
I thought Bar-Tek used a cambelt profile on their kit. Seem to remember a lot of complaints about them on C.P.
Re: Toothed Pulleys
« Reply #8 on: July 11, 2011, 09:02:42 pm »
some german ones did, but if you look at the photos they are same profile and but a shorter belt.  square tooth are much longer spaced
Offline AlexG40
Re: Toothed Pulleys
« Reply #9 on: July 11, 2011, 09:30:28 pm »
Wait till winter and buy my PSD ones off me.  :P
Offline xrrich
Re: Toothed Pulleys
« Reply #10 on: July 11, 2011, 09:38:03 pm »
winter is along time cant get power down also! aha
How come you selling yours?
Offline scotsjohn
Re: Toothed Pulleys
« Reply #11 on: July 12, 2011, 06:54:12 am »
That's what I was looking at, but on the pulleys. The space between the teeth looks much bigger than the teeth themselves. Doesn't look like a regular 8mm pitch.
Offline ereeiz
Re: Toothed Pulleys
« Reply #12 on: July 12, 2011, 11:19:06 am »
I do have the intention of ordering some in via work but I got carried away and fitted them before measuring them :/
Realistically I doubt I will now unless these wear out. I think Justin is/was doing the same thing too, lol.
Offline xrrich
Re: Toothed Pulleys
« Reply #13 on: July 16, 2011, 01:06:08 pm »
Luckily i have sourced a brand new set of PSD toothed pulleys.
Right just wondering should i replace the 4 allen key bolts on the pulley for brand new ones or will it be ok to use old ones.
Any other things i might want to know before fitting them.
Helpful hints or tips
RIch
Offline scotsjohn
Re: Toothed Pulleys
« Reply #14 on: July 16, 2011, 06:21:35 pm »
Hope these aren't off e-bay mate. There's some dodgey PSD lookalikes on there; missing the guide rails.
