Uprated as standard. From the factory they were oil filled dampers, it's possible this is still the case (or maybe now they are only semi-oil filled ha ha!). New ones, whether standard spec. or uprated, will be gas filled cartridges and drop inside the suspension leg once you've drained the oil and thrown the original pistons away.
