Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
Exhaust... knocking
« previous
next »
Pages: [
1
Go Down
Author
Topic: Exhaust... knocking (Read 3186 times)
rocore
Exhaust... knocking
on:
January 21, 2009, 06:48:26 pm »
Changed the rear exhaust bungee last week as the old one was nearly worn out and stretched... Now the new one is on the exhaust knocks on the bottom of the car when going over bumpy ground... Seems as though the mid section is flexing? but its not blowing anywhere?!
Not a huge issue but one of those little things that really grind you down!
supercharged spaniel
GRRRRRRR
Re: Exhaust... knocking
Reply #1 on:
January 21, 2009, 07:38:13 pm »
have you still got the little bump stop in between the two back exhaust hangers?
rocore
Reply #2 on:
January 21, 2009, 07:54:56 pm »
yep, still there. Seems like it is flexing in the middle... just below handbrake area...
Administrators
Housewives heart throb
Reply #3 on:
January 21, 2009, 09:11:02 pm »
has middle rubber gone??
Probably the oldest G driver in the Universe.
Reply #4 on:
January 21, 2009, 09:40:00 pm »
What diameter are you running? Clearances get pretty critical at the 60mm mark.
rocore
Reply #5 on:
January 22, 2009, 08:35:38 am »
Running standard system at the moment. Think i need to get the car up and have a proper gander underneath.
G40supercharged
Reply #6 on:
January 22, 2009, 08:44:23 am »
Check the joint between the catalyst section and the middle section. This sits just above the transmission tunnel brace. The exhaust clamp at the joint can hit the brace as the engine moves.
rocore
Reply #7 on:
January 26, 2009, 08:34:04 am »
Believe it or not.... All the problem was, was the U-bolt connector was put on upside down and knocking like hell.
Turned round, problem solved and its like driving a different car!
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Exhaust... knocking
