Club G40
May 24, 2012, 01:28:05 pm *
Pages: [1]   Go Down
Author Topic: wideband lambda  (Read 142 times)
gaz g40
Offline Offline
« on: February 05, 2012, 03:32:50 pm »
On buyin my psd exhaust there's a nut for a wideband what's a good cheap/road use kit and suggestions? Also thanks to alex for selling me exhaust and reorganising stuff so I could get it yesterday
Cheers gareth
AlexG40
Offline Offline
« Reply #1 on: February 05, 2012, 03:35:51 pm »
You're welcome. Hope you're happy.
I don't think good and cheap go together in the case of Wideband AFRs. Mine is a Stack unit but I know others are using different ones. None are particularly cheap though.
Alexiskayak_7
Offline Offline
« Reply #2 on: February 05, 2012, 07:09:08 pm »
Innovate MTX-L is a ''cheap'' wideband...
gaz g40
Offline Offline
« Reply #3 on: February 05, 2012, 07:55:01 pm »
Ok then maybe u should of said for road use just to keep an eye ob things an where would people recommend buyin from. Very happy with the quality thanks
AlexG40
Offline Offline
« Reply #4 on: February 05, 2012, 08:49:06 pm »
If you just want to keep an eye you maybe don't need a wideband at all? You could use a normal AFR. Not as accurate but does the job. The main advantage of the wideband for me was the ability to recall data from a run without having to look at the gauge whilst driving.
Oli b
Offline Offline
« Reply #5 on: February 08, 2012, 08:31:15 pm »
ive got the inovate mtx-l and im very happy with it cost is quite high but its a very nice piece of kit .i recomend it highly if you want to see exsactley how your car is running
Pages: [1]   Go Up
Jump to:
