Club G40
May 24, 2012, 01:04:26 pm *
Pages: [1]   Go Down
Author Topic: rev counter wiring  (Read 285 times)
poloandyb
Offline Offline
« on: February 01, 2012, 05:37:38 pm »
hi all, when i had my 1.4 gt engine in my van i was using a tim rev counter.now iv put a g40 engine in i'd like to use the same revcounter,on the gt i ran it off the ignition module but iv tryed on the gee and it dosent work from there..dose anyone know where i splice into the loom to get a pulse for the rev counter?Huh?
hope someone can help
cheers andy
ereeiz
Offline Offline
« Reply #1 on: February 01, 2012, 09:56:27 pm »
It's in the wiring diagram in the haynes manual, I went through it 5-6 years ago and can't remember what I did. Tried looking in there?
grungeisdead
Offline Offline
« Reply #2 on: February 02, 2012, 12:46:48 pm »
connect the rev counter wire to the negative take off on the coil (its under a cap by the plug, 8mm nut
youngprodigys
Offline Offline
G 3URO
« Reply #3 on: February 22, 2012, 11:39:35 pm »
rev pulse from ecu is the red/black from the yellow plug in the ecu loom
Pages: [1]   Go Up
Jump to:
