Classifieds
Articles
Forum
Merchandise
Home
May 24, 2012, 10:13:06 am
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
News
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
Gearbox gaskets/sealing?
Pages: [
1
Go Down
« previous
next »
Author
Topic: Gearbox gaskets/sealing? (Read 86 times)
AlexG40
Offline
on:
January 29, 2012, 05:33:26 pm »
My G40 box has developed a leak and I think it's coming from one of the joints in the housing. There's nowt in the Haynes about this so can anyone tell me what the crack is with firstly what's there? And secondly how to go about fixing it? I've never had a gearbox apart before as it's pretty much black magic but this box is lovely to use so I wan't to sort it properly.
Administrators
Online
The CV joint killer
Re: Gearbox gaskets/sealing?
Reply #1 on:
January 29, 2012, 07:45:42 pm »
Do you mean from the joint between the two halves of case? Quite simple to fix, just remove the driveshaft flange cups by undoing the two Allen head bolts in the centres of them. Then remove the ten or so 10mm bolts from all around the casing (do not remove the torx head bolts on the front of the box!!!) and tap the clutch housing side off. Stand the box on it's end while you do this with the black end cover down. Then clean both mating surfaces and scrape with a blade to get anything off them, apply some sealer and put the two halves back together, torque is only something like 20 lb/ft but i just normally nip them up by hand to what feels right to me!
The best thing I've found as a sealant is something called Threebond 1194. People use this for sealing porsche crank case halves together and it seems to do a good job, although it's not particularly cheap. I also put a bit of locktite on those Allen bolts in the driveshaft flange cups to keep them tight as you don't want them coming off.
Administrators
Online
The CV joint killer
Reply #2 on:
January 29, 2012, 07:47:10 pm »
Oh, the hardest part about fitting both parts back together is making sure the gear selector rod cup locates properly on the ball inside, not too bad though, just lower it on slowly and keep watching between the halves, you'll see what I mean.
AlexG40
Offline
Reply #3 on:
January 29, 2012, 07:50:02 pm »
Sweet, cheers matey.
Pages: [
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Club G40
=> Announcements
=> General Car Chat
=> General Chat
=> Ongoing Projects
=> Meets and shows
=> Photos and videos
Technical
=> Engine and Transmission
=> Chassis & Braking
=> Electrical
=> Engine and transmission FAQ
=> Chassis FAQ
=> Electrical FAQ
=> Superchargers / G-Lader
=> Turbochargers
=> Superchargers FAQ
=> Exterior and Interior
=> Exterior and Interior FAQ
Classifieds
=> Parts for sale
=> Traders parts and services
=> Cars for sale
=> Wanted
=> Misc For Sale
=> Group Buys
Club Sponsor - PPP
=> Polo Performance Parts
Reviews
=> Company Reviews
=> Seller/Buyer Feedback
Loading...
