Classifieds
Articles
Forum
Merchandise
Home
May 24, 2012, 10:05:42 am
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
News
Home
Help
Calendar
Login
Register
Technical
Engine and Transmission
forger pistons opinion
Pages: [
1
Go Down
« previous
next »
Author
Topic: forger pistons opinion (Read 326 times)
xandyx
Offline
on:
January 27, 2012, 10:26:03 pm »
hi there!
i bought a few months ago another G shell, and now i'm going to pick up an enginenext week.
there's a fella selling a set of forged pistons for a bargain.
just wonder if they are suitable for daily driving. what are the advantages and disadvantages of using them?
i think they are wiseco's, don't know about the bore, just know they are bigger that standard.
André
Offline
ooppss!
Re: forger pistons opinion
Reply #1 on:
January 27, 2012, 10:59:17 pm »
I use to use mine as a daily and i never had a problem. I actually thing it helped driving as yo dont need to put your foot down as much,
GR40
Offline
Reply #2 on:
January 29, 2012, 07:41:17 pm »
I doubt there is any disadvantage to them...
Traders
Online
I know naathing..
Reply #3 on:
January 29, 2012, 08:14:15 pm »
Forged piston by it's nature takes more heat energy to expand, so there's more blowby on cold start and possibly slightly lumpier running from cold. After a few seconds they're fine- you can tell the differance between a 1341cc start up and a 1272cc.
xandyx
Offline
Reply #4 on:
January 30, 2012, 12:52:40 am »
thanks for your reply's!
i've been searching the web, and they talk about oil comsumption and that the piston rings don't last longer as standard. did you notice something similar?
my plans so far, are to use a spare charger that i have, with rs2 mod, 65mm toothed, and a ppp chip (will order).
don't you think it's worth going forged? as i sayd, will be my daily car, and once in a while i drive a bit of boost here and there!
Administrators
Online
The CV joint killer
Reply #5 on:
January 30, 2012, 09:16:10 am »
well it'll cost you about £1000, what do you want from the car? people dont tend to buy those pistons purely because they are forged, it's more about the increased bore giving more power.
randombadger69
Offline
Reply #6 on:
January 30, 2012, 12:34:42 pm »
I just did a 76mm overbore.
Machining cost
Bore block to pistons £100
Face block £30
Lighten and face flywheel £45
Balance crank F/W and clutch £72.50
Plus vat
£297
Rods and pistons were £900
rings for pistons are £125 for wossner if replacements are needed.
From VW. Core plugs, main journal bolts, breather pod, flywheel bolts, oil pump and chain were £255 inc vat. (Add a main crank bolt to that list).
And an elring block repair kit is 80 Euro's off Bar-tek. (Some off the end plate gaskets are now obsolete from vw as was the water pipe gasket).
KS main and big ends were £60 off RS engine supplies. Thrust washers were about £7.
Should give you a realistic price guide for re-building a block.
The main advantage i can see other than increased bore and strength is the forged pistons shoud dissipate the heat away from the crown of the piston more efficiently. Thus helping reduce cylinder temperature, increasing charge density slightly.
Administrators
Online
The CV joint killer
Reply #7 on:
January 30, 2012, 12:45:37 pm »
why did you buy rods? do you just mean standard ones?
AlexG40
Offline
Reply #8 on:
January 30, 2012, 01:05:39 pm »
What CC does a 76mm overbore equate to?
randombadger69
Offline
Reply #9 on:
January 30, 2012, 01:06:03 pm »
because they were shiny
They are considerably lighter though.
1306.5 iirc.
AlexG40
Offline
Reply #10 on:
January 30, 2012, 09:05:04 pm »
Out of interest, any reason for not going bigger?
xandyx
Offline
Reply #11 on:
January 30, 2012, 09:49:32 pm »
i will get the pistons really cheap, like 150euros (125£) they only rode for 300miles. the guy then build a 1.6 golf block with a t28 turbo.
allready talk to a guy to order new rings. i can get the block bored for 100euros (85£) and get the flywheel lightened and balanced for under 50£
my only doubt is reliability for daily use. i just want to reach about 150, 160hp, don't know if worths spending that amount of money.
maybe i can reach that power safelly with cast, what do you think?
i remember reading that there's someone near to 200hp using cast pistons. i know it's a big risk..
thanks for your reply's!!!
AlexG40
Offline
Reply #12 on:
January 30, 2012, 09:53:41 pm »
You can piss 170 plus with stock internals, I'm pretty sure Hayesey is running stock insides at 190bhp.
If you need a good home for those pistons let me know...
Administrators
Online
The CV joint killer
Reply #13 on:
January 31, 2012, 09:17:34 am »
yeah I have standard cast pistons and have 194bhp. It's perfectly safe, all about getting the fuelling right and being careful to have a rich mixture at high loads to keep it safe. With larger bore it would make more power but I didnt have the budget for it all.
Justin14100
Traders
Offline
Reply #14 on:
January 31, 2012, 01:10:15 pm »
Standard internals are amazingly strong, if you were going forged it'd only make sense to go to 77mm for the extra power it would produce. Otherwise the standard bottom end is strong enough.
Pages: [
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Club G40
=> Announcements
=> General Car Chat
=> General Chat
=> Ongoing Projects
=> Meets and shows
=> Photos and videos
Technical
=> Engine and Transmission
=> Chassis & Braking
=> Electrical
=> Engine and transmission FAQ
=> Chassis FAQ
=> Electrical FAQ
=> Superchargers / G-Lader
=> Turbochargers
=> Superchargers FAQ
=> Exterior and Interior
=> Exterior and Interior FAQ
Classifieds
=> Parts for sale
=> Traders parts and services
=> Cars for sale
=> Wanted
=> Misc For Sale
=> Group Buys
Club Sponsor - PPP
=> Polo Performance Parts
Reviews
=> Company Reviews
=> Seller/Buyer Feedback
Loading...
