Club G40
May 24, 2012, 08:38:32 am *
Welcome, Guest. Please login or register.
Did you miss your activation email?
   Home   Help Calendar Login Register
Pages: [1]   Go Down
Author Topic: Steering Rack Play  (Read 271 times)
Robin
Offline Offline
194bhp - 1341 Turbo
« on: January 02, 2012, 07:14:31 pm »
I've got a lot of steering wheel play on the Polo, there is a good few degrees of movement before the wheels start to move, has only recently happened so i know something isn't right.
Not had a chance to look at what the problem is yet as i been doing other stuff on the car but i will have a look at it next weekend, anyone got any suggestions on what is likely to be the cause or if anyone has had the same problem before?
Administrators
Online Online
The CV joint killer
WWW
« Reply #1 on: January 02, 2012, 08:36:00 pm »
Check the nut on the clamp on the steering column down near the pedals
Robin
Offline Offline
194bhp - 1341 Turbo
« Reply #2 on: January 02, 2012, 10:54:17 pm »
Cheers Hayes. Will check that out!
Robin
Offline Offline
194bhp - 1341 Turbo
« Reply #3 on: January 06, 2012, 06:58:33 pm »
Cheers Hayes you were right, 13mm bolt has worked loose!
Administrators
Online Online
The CV joint killer
WWW
« Reply #4 on: January 07, 2012, 03:36:22 pm »
Cool, no worries. Happened to my old GT once too
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
