Club G40
May 24, 2012, 04:04:32 am *
Welcome, Guest. Please login or register.
Did you miss your activation email?
   Home   Help Calendar Login Register
Pages: [1]   Go Down
Author Topic: Charger seals  (Read 287 times)
chief40
Offline Offline
« on: November 19, 2011, 08:05:50 pm »
I took the G40 off the road last march, mainly because the intercooler was filling up with oil and the smoke from the exhaust was horrendous!
Excesive oil was also being thrown out of the throttle body, so i thought ....charger seals.
Darren at G-Werks rebuilt the charger and i put it back on the car but due to a suspension and brake rebuild i didnt use the car until 2 weeks ago.
i drove the car to the MOT station (Where it passed).
On the way home the same thing happened........smoke, oil etc.
I took the charger and Intercooler off today and they were literally FULL of oil!
Any ideas anyone?
I have tried phoning G-Weks for the last 2weeks but no answer.
The only thing i can think it could be is the charger seals again?
Richg40
Offline Offline
« Reply #1 on: November 19, 2011, 08:14:15 pm »
G-werks quit trading dude. Sounds like charger seals to me. 1+1=2.
chief40
Offline Offline
« Reply #2 on: November 19, 2011, 08:17:53 pm »
Thanks Rich,
Yea thought they had!
Guess i will have to find someone else to look at it for me1
G-Werks are meant to have done the seals! Sad
Administrators
Offline Offline
Housewives heart throb
« Reply #3 on: November 19, 2011, 11:01:41 pm »
they will have done the seals, but its quite common for them to go when first serviced
Did you run the charger in?
chief40
Offline Offline
« Reply #4 on: November 19, 2011, 11:06:13 pm »
Yep, i kept the revs low and took a real steady ride to the MOT station.
I'm running the boost return mod, do you think that will make a difference?
Offline Offline
ooppss!
« Reply #5 on: November 20, 2011, 08:53:02 am »
I run the mod and my seals were fine but have experienced a problem that sounds similar to yours. I ran the charger in for 500 miles before boost etc and then about a month ago (having done 5k since rebuild) my charger was kicking out soo much oil that my dipstick was dry. Couldnt find out what is was so asked on here what the problem was. Pete said sounds like the seals are weeping oil. Someone then mentioned about the breather pipe being blocked or kinked. So when i went back out i checked it all and gave everything a wiggle and then after that it was all fine. Problem was a trapped breather pipe. So i would make sure your breather pipe isnt kinked or blocked etc as if the crank pressure cant escape properly it will find the weakest point and apparently the charger seals are the weakest point. Then drive off boost for a few more miles to let the charger seals bed in.
chief40
Offline Offline
« Reply #6 on: November 23, 2011, 09:16:12 pm »
Thanks Jezza, i will have a look at the breather.
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.16 | SMF © 2011, Simple Machines Valid XHTML 1.0! Valid CSS!
