Club G40
May 24, 2012, 02:09:59 am *
Pages: 1 [2]   Go Down
Author Topic: turbo oil drain fitting (the one you weld into the sump)  (Read 1017 times)
cheys03
Offline Offline
« Reply #15 on: November 20, 2011, 04:57:18 pm »
Not wide enough, both the feed and return are too narrow for your average turbo.
grungeisdead
Online Online
« Reply #16 on: November 20, 2011, 11:33:10 pm »
Yup you need a large return line otherwise the pressure will be too high and the oil will back up and push past the seals in the turbo, leading to a schmokey exhaust!
I used an AN-10 fitting to the sump and got it TIG'd on the inside so it looks alot neater.
got all my fittings and hosing from torques.co.uk but through thier ebay shop
« Last Edit: November 20, 2011, 11:38:38 pm by grungeisdead » Logged
etches69
Offline Offline
« Reply #17 on: March 21, 2012, 07:39:08 pm »
Sorry to bring up this old thread, but can anyone confirm that the AN-10 fitting is the one for the standard oil return?
grungeisdead
Online Online
« Reply #18 on: March 22, 2012, 01:05:04 am »
im running a T25 btw not a K03 which I think you are planning on?
etches69
Offline Offline
« Reply #19 on: March 22, 2012, 09:40:26 am »
Yeah, hmmm hayesey has posted what looks like the A10 and he's using a K03 like me.
these are the return feeds i've got so I've got a choice
Screw fit is the ideal one but I don't know the male fitment
Administrators
Offline Offline
The CV joint killer
WWW
« Reply #20 on: March 22, 2012, 09:52:16 am »
hmm, I think it's AN-10 yeah, it's too long ago to remember properly!
Although my drain pipe is a PSD one anyway so may or may not be the same fitting as comes off a passat or audi a4 or whatever those are off.
etches69
Offline Offline
« Reply #21 on: March 22, 2012, 10:54:37 am »
The screw fixing is a custom job which looks like the female AN10 but for the sake of 3 quid of ebay worth a shot with the male AN10
Administrators
Offline Offline
The CV joint killer
WWW
« Reply #22 on: March 22, 2012, 11:11:05 am »
actually it could have been a JIC fitting now I think about it.  I wonder if I still have the order email from Think in any of my email archive folders, I'll have a look.
Administrators
Offline Offline
The CV joint killer
WWW
« Reply #23 on: March 22, 2012, 11:14:56 am »
ha well that was easy, found the emails from/to Think-Automotive from 2008 and it has:
Quote
WOS7-10 : steel weld on -10JIC fitting
but as I say, this is for a PSD oil drain so perhaps not the same as yours.  There is a way of telling the type of fitting by going off the angle of the seat inside the fitting but I can't remember exactly how to.
« Last Edit: March 22, 2012, 11:17:34 am by hayesey » Logged
etches69
Offline Offline
« Reply #24 on: March 22, 2012, 11:35:25 am »
Cheers Paul,
ill have to browse around see if I can find some info on figuring out the fitment!
Here is a better pic if it comes back to you
The cap is 1ich deep or 13mm , threads are roughly 1.2-1.4 mm apart
« Last Edit: March 22, 2012, 11:52:32 am by etches69 » Logged
Administrators
Offline Offline
The CV joint killer
WWW
« Reply #25 on: March 22, 2012, 12:55:08 pm »
this might be of some use:
http://www.jgbhose.com/base_pages/coupling_identification.asp#north_american
I'd probably hazard a guess at JIC though.  To be fair, you could just buy a -10JIC and AN-10 fitting from Think, they aren't expensive.  A quid or so each more than likely.
Administrators
Offline Offline
The CV joint killer
WWW
« Reply #26 on: March 22, 2012, 12:58:34 pm »
OK well doing a bit of googling and reading, JIC and AN are the same:
http://en.wikipedia.org/wiki/JIC_fitting
So just order JIC-10.  That fitting you have definitely isn't BSP anyway.
etches69
Offline Offline
« Reply #27 on: March 22, 2012, 04:40:26 pm »
Cheers Paul shall know by next week!
Pages: 1 [2]   Go Up
Jump to:
