Club G40
May 23, 2012, 08:21:45 pm *
Pages: [1] 2 3   Go Down
Author Topic: Toothed pulley belts for sale  (Read 11084 times)
Administrators
Offline Offline
Housewives heart throb
« on: October 10, 2008, 10:45:14 am »
Right, we've sorted a supply for toothed belts.  They are german quality made under Continental by Contitech.
These are importantly the right length, width and tooth profile for PSD toothed belt pullies. So they shouldn't wear your pully out like wrong profile ones may. They are a HTD - high torque belt.
Always handy to have a spare in case of teeth strippage or belt snap.
These are £14 a belt and £3 delivery - paypal accepted.
« Last Edit: May 16, 2012, 05:00:20 pm by PeteG40 » Logged
busy t
Offline Offline
« Reply #1 on: January 24, 2009, 10:37:57 am »
just recieved my belt this morning and it is too big...my pulleys say PSD on them so they are definately from pitstop developments, does the pulley size make a difference? will you be able to get one that is the same size as a polo 16v cambelt?
busy t
Offline Offline
« Reply #2 on: January 24, 2009, 01:07:29 pm »
right scratch that previous comment^^
after some more research and a look at my charger i realised that you can move the charger to tension the toothed belt. there is a large allen key bolt that looks to me like the charger pivots on (to the right of the charger) and then another large bolt (to the left of the charger). are these the only two bolts i need to loosen in order to move the charger and tension the toothed belt?
« Last Edit: January 24, 2009, 01:35:10 pm by busy t » Logged
Administrators
Offline Offline
« Reply #3 on: January 24, 2009, 02:54:27 pm »
yes it is, although you sometimes have to alter the alternator position (a little bit of movement in this makes a lot of difference)
pete
busy t
Offline Offline
« Reply #4 on: May 06, 2009, 06:14:50 pm »
can you do a 1020 for the same price?
Administrators
Offline Offline
« Reply #5 on: May 06, 2009, 06:23:04 pm »
they only do 960s and 1040s  - apparently 1016 is another size and 1000 - but they tend to be custom made - our supplier doesnt do them.
Can you not get 1040s to fit, a few people (myself included and Samg40) have had to fiddle with the alternator/boost pipe. but they fit eventually!
busy t
Offline Offline
« Reply #6 on: May 06, 2009, 08:03:46 pm »
I have the charger adjusted as much as it will go, and the mounting bracket for the alternator does not have a space to adjust the position. It's still too slack, it hits against the top engine mount. Any ideas?
Administrators
Offline Offline
« Reply #7 on: May 07, 2009, 07:13:27 am »
undo all alternator bolts. There are only mm of movement but shove it down and out as far as you can!.  then nip it up and try to tension the belt
busy t
Offline Offline
« Reply #8 on: May 07, 2009, 04:09:10 pm »
Does the bracket on your alternator not allow any adjustment dknight? How have you got around it? You reckon a 1020 belt will do the trick?
quiksilver_jake
Offline Offline
« Reply #9 on: May 07, 2009, 04:24:36 pm »
Pete do you do 1000? mine says 1000 8m omega HP optibelt
20mm width ?
Administrators
Offline Offline
« Reply #10 on: May 07, 2009, 04:48:47 pm »
after andy strange told me - i adjusted my alternator, as did samg40 on here and it worked fine.
Can't get hold of 1000 or 1020s - they are custom lengths
1040s are easy to get hold of, hence why psd used them for their design
busy t
Offline Offline
« Reply #11 on: May 21, 2009, 11:58:50 pm »
Have you managed to tension your belt (sounds wierd when said out loud Tongue) yet?
There is a part on the gsf web site which i reckon is the plate that attatches the bottom of the alternator to the block, with the gap to allow adjustment. Check out part no 90498. What do you think?
If not the only other option i can think of is a 1020 belt, however the cheapest i have been able to get them is £28 each from a guy on clubpolo.
This is the only problem with my car now and it is blagging my head.
Anyone any ideas?
Administrators
Offline Offline
« Reply #12 on: July 19, 2009, 07:54:17 pm »
hmm, tbh I do think they are overkill - I've only ever heard of original belts snapping - or one where a 60mm pulley was used, which caused the top bearings to seize.
LeonL
Offline Offline
« Reply #13 on: November 07, 2009, 09:07:50 am »
Still sell these?
Administrators
Offline Offline
« Reply #14 on: November 07, 2009, 09:24:53 am »
we do yes
Pages: [1] 2 3   Go Up
Jump to:
