Club G40
May 23, 2012, 08:15:06 pm *
Pages: [1]   Go Down
Author Topic: T25 Water Line Fittings  (Read 359 times)
grungeisdead
Offline Offline
« on: July 05, 2011, 10:27:57 am »
Morning!
Does anyone know the size of the water inlet and outlet ports on a T25 turbo, one is larger than the other, but they both seem to be mahoooosive.
Also regarding the water lines, can i feed the water inlet off the header tank take off from the thermostat housing, and the water outlet to the header tank?
Ta!
grungeisdead
Offline Offline
« Reply #1 on: July 06, 2011, 11:01:35 am »
Well I've found that they are M14 and M16, so I need to get hold of a couple of right-angled banjos.
anyone know of some good stores to purchase these bits, as i cant see to find them!
failing that ill just get M14/M16 to AN6 adaptors and get some braided hoses made up, a visit to pirtek might be in order
Pages: [1]   Go Up
Jump to:
